temporary primer
I would like to take care of some surface rust on a 901 floor pan. Would like to protect from re- rusting and be able to easily remove for a pro to do a final repaint..Spray can or brush on is ideal...Thanks
`S`hammer |
dkbautosports.com
901 are you trying to piss off peugeot ???? as a shop owner i hate when people do things like that !most of the time it will only cost you more money in the long run . why are you trying to do some thing with the rust ? if your going to have a shop do the refinishing then you should be asking the shop that is going to do the work for you how they want it done ! if your going to have it blasted and you want to top coat the bare metal then it should be refinished right from the get go . how with all that said . you can brush and roll on rust-shield and some hardener( mixed 8 to 1 part hardener) so it can be sanded and retop coated . if you do not add the hardener it will be a pain in the ass to top coat .
