Porsche Nut
Anyone have exp. with Lizard Skin?
I have seen this product used on some other forums. I want some sound control as well as heat control, but do not want the non-original look of using sheet products like Dynamat. Plus the Dynamat is very expensive, especially if you use a lot of it. What I am thinking about doing is spraying the Lizard Skin and if it does not look like the Wurth SKS Stone guard, go over it with the Wurth product. Need to be sure that the Lizard Skin can be top coated, but I cannot see why not. They are both water based products.
Lizard Skin Ceramic |
300hp 1800lbs is the goal
Just doing some searching, cause I will need something once all my rust repair is done. That Lizard Skin seems quite pricey. Edit... okay looks like they lowered all their prices.... the gun used to be like 150$ too
![]() Insulating Paint Additive Makes Paint Insulate Micro glass spheres added to latex paint is supposedly all the LS is. You can get the spheres for pretty cheap. I wouldn't want to trust latex paint anywhere on my car tho..... I was going to tremclad rust paint everything. Now I'm thinking I'll add those spheres to the tremclad for the interior floors, instead of sound mat
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier.
Porsche Nut
When I was searching it sounded like the LS used to be like 400$ for 2gallon and $150 for the gun (That's why I added that edit) I see on their site it's cheaper now (for both)
Tremclad now has a waterbased rust paint, but I won't be using any of that near my car... just the nice toxic stuff... save the planet...meh ![]() I'll try the spheres with tremclad... and I'll pickup a cheap undercoating gun from princessauto (Canada's Harbour Freight) I'm gonna hold off paint till the rust is fixed, and cage is in tho
Porsche Nut
Yes, the gun is nothing more than a basic under coat gun. would you mix the ceramic spheres into something like POR15 and shoot it? I have used both POR and Zero Rust. I like the way POR goes on with a brush, thick, but do not care for the shinny finish. I have bought ZR in qts but have not brushed it on yet.
POR15 needs a topcoat, or it will get damaged by UV light. I believe Zero Rust doesn't need a top coat (similar to Tremclad from past research) They sell flat colours of tremclad.... I have to figure if I want high gloss orange, high gloss black, or flat black for my interior
When I get a bit further into the rust repair I'll pick up some of the hytech additive. I plan to paint the entire interior/exterior of the car with it, then I'll undercoat the wheel wells.
Have you thought about using Line-X? They offer coating for purposes other than truck bed liners. I am thinking of Line-X as the undercoating instead of Wurth.
