Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
D911SC's Avatar
Opinions please
I've posted various threads on this project of mine and the responses have really helped me to get to the stage I am currently at. Thanks to all who have given me advice.
Before I lay on some color I wanted to get some opinions on what is the preferred option. I apologise if this seems like a trivial topic but I am struggling to make a decision!!
I am restoring the underside of my Zinc Metallic 1983 Euro SC. So far all suspension, brakes, steering, etc is out and I have cleaned it up and repaired all the damaged areas. I just sprayed Wurth SKS in grey on the entire underneath including wheel wells.
Now it's time for color and I am definitely painting the wheel wells. My question is whether to paint underneath as well. I prefer the look of a painted finish but stone chips and grime may ruin it over time. It will get cleaned from time to time but as the car will be driven it's not going to be completely protected from reality.
If I leave the underside in SKS grey then I would use the seam as the paint line. I still plan to paint the front boot and engine bay in body color.
The car is not a daily driver (3000 miles per year). I am not trying to restore it to a completely original spec, in fact the use of grey SKS is already a compromise as the beige is NLA.
I had considered painting the underside and wheel wells black but in the end I wanted body color in the wheel wells.
The question is then, should I spray with body color underneath or leave it grey?
Here is a pic of the grey as it is at the moment (still got a couple of small areas to touch up)
My first love - 1993 964 C2 Manual Coupe
My second love - 2021 Macan GTS
Old 10-04-2010, 04:43 PM
Bird. It's the word...
Fishcop's Avatar
FWIW, I'm painting the underside of my car - over SKS as part of my restoration.
You're right, the paint will be chipped and wear over time, but "whilst you're there"
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 10-05-2010, 01:00 AM
D911SC's Avatar
The number of "whilst you're there" projects I've got on the go are bigger than the actual project!!
One more won't hurt.
I'm leaning the same direction as you John - thanks for the input.
Old 10-05-2010, 03:36 AM
D911SC's Avatar
Any other PP members willing to throw their 2c in?
Thanks.
Old 10-05-2010, 08:57 PM
rickharrison's Avatar
Black on the bottom?
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 10-07-2010, 10:53 AM
Formerly reformed
Think I'd go with black. It's easier to spot-cover when needed.
1968 911P (Paperweight)
Old 10-07-2010, 02:17 PM
Registered speed offender
78SCRSMAN's Avatar
^^^ +1 ^^^
I left mine black (epoxy primer) no SKS, in order to spot and remedy potential problems. Not to mention paint is not cheap!
If you keep looking back, you'll never move forward.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html
Old 10-07-2010, 07:28 PM
D911SC's Avatar
Thanks for the comments so far guys
Old 10-08-2010, 03:12 AM
i would go with wurth black under coating up the bottom of the rocker panel with a tape edge to deflect rocks that may chip the paint, and it is black so you can spray the rest of the can on the bottom pan after paint is complete to cover over spray for a clean look.
Old 10-28-2010, 03:38 PM
