Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
rust rust !
hi everyone .this my 77 . i m doing the bodywork now . and i get confused about this . [img]
i used the de.ox.it to cleared the panel . just want ask is this good enough to get primed ? thanx
Old 12-18-2010, 06:23 PM
That panel looks pretty pitted. If it were me I'd hit it with an 80 grit pad on a DA and see what that does. I'm sure it's gonna leave some deep pits - so finish it off with a 36 grit grinding disc in the areas needed then go back to the 80 DA before building it up with some primer. Go easy using the 36 grit disc - use the flat surface not the edge of the disc to prevent sanding too deep. Also keep the pad moving - don't stay in one place too long.
Good Luck-
Old 12-21-2010, 03:53 AM
dkbautosports.com
962porsche's Avatar
if it was in my shop i would spot blast it . you can buy little spot sand blasters for cheap . its always best to remove the rust by blasting it rather than trying to sand or grind it off . by sanding and grinding you will also be removing metal making the panel thinner . if you leave even one little pit of rust it will come back making all your hard work point less . after its sand blasted spray a coat of chromated etch primer on it then do your body work over the top of that . its more than ok to do fill work over a etch prime just sand the etch primer with a 180 grit paper .
Old 12-21-2010, 04:57 AM
cool . thanx
Old 12-21-2010, 09:55 PM
