tseybold
Debre in paint
Hey guys,
Well I have started my first and probably last paint job. I am telling you it's been alot of hours, stripping , sanding, filling, sanding, sanding and now I finally sprayed my trunk. hood and doors, engine cover on my 814. The actual finish looks pretty good but not up to my or your standards. No matter how clean I think I have everything, tack cloth and re-tack cloth strain and restrain the paint . I keep getting small particles in the finish?? Photos attached
tseybold
Debre in paint
Sorry did not upload painted finish
![]() Any suggestions would be great |
paint
what paint did you use? Single stage or two stage? Two stage you can sand the clear and buff and polish removing most of those imperfections. If single stage if dry you might also carefully sand and buff, of course depending on what type of paint you used and how thick it is, and remember to wait until it is dry. Jim
Just so you know the rest of the car gets easier. It is always difficult to spray on the flat surface and not get those small particles. You might want to sand the doors, rehang and shoot them when you paint the rest of the car, so the only difficult items are the hood and trunk. Jim
tseybold
Yes it is a single stage paint and yes I did apply heavy. I started to wet sand with 1,200 grit to see what it would result. I think that is the way to go, Now I need to get some compound to bring the shine back.
Thanks for the information and I will keep on trucking can't stop now.
They do make finer sand paper. I just sanded some black wheels I painted with 2500 grit it removed just a little orange peel and buffed up quickly. More sanding, removes smaller amount of paint. Use a little dish washing soap in the water to lubricate while sanding, just in case you do not know that. Jim
tseybold
Yes I have been reading up on similar posts and I guess I am not to far off.
I will have to regroup and color sand, buff / polish. I thought my hours of work were behind me. Boy was I wrong. But I am glad to hear that this is not uncommon for a DIY in the garage. I will post some photos when I finish the car Thanks a;;;llll |
tseybold
Debris in Paint
Must apologize for my incorrect spelling .
