-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   Picklex Users- Is this normal? (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/651318-picklex-users-normal.html)
TC911e 01-16-2012 05:14 PM
Just finished, I think, patching, welding, grinding, re-welding, etc the front valence and gave it a spray and brush on of Picklex to try to protect it until I get around to putting primer on. Now it's got the orange haze that looks all the world like surface rust. I even ran the scrubby over it an re-applied the Picklex, but got a similiar result. Is this normal?
There really wasn't any rust on this part to start with or following the repairs, it's mostly new metal especially in the shot of the corner from inside the trunk. Just looking for other opinions before I go further.
Tim
http://forums.pelicanparts.com/uploa...1326762808.jpg
http://forums.pelicanparts.com/uploa...1326762837.jpg
hemeoncdoc 01-22-2012 08:33 PM
I have the same problem. I believe it is rust. Not sure if Picklex 20 went bad or what. I have not yet contactebdthe company but intend to.
Fishcop 01-22-2012 11:38 PM
You may find it's actually zinc phosphate reacting to moisture - not actually rust. Just scuff it all down with a red scuff pad and epoxy or etch prime when ready.
TC911e 01-23-2012 08:41 PM
Thanks, I'll give that a shot. I did give it another light squirt with the spray bottle and brushed it on again and it didn't seem to come back orange. Maybe I just didn't get enough on to start with.
drcoastline 01-24-2012 05:56 AM
I have never used picklex. I think John is correct. I have used Eastwood Metal Etch and POR15 Medal Ready which are similar products and they did the same thing.
Fishcop 01-24-2012 04:23 PM
Here's a shot from my car a day after application whilst I was working my way to clean metal. I scuffed it all up prior to epoxy...
http://forums.pelicanparts.com/uploa...1327450839.jpg
pksystems 01-31-2012 09:21 AM
If I recall correctly, you are supposed to dry the surface after applying picklex..... spray it on, scrub it, let it sit a few minutes, and wipe it dry.
The carrier for the phosphoric acid is water I believe, so it probably is a light surface rust...
Classic 01-31-2012 02:10 PM
Looks like you let it dry on the surface, hence the light coating reacting with the atmosphere.
I tend to only do a small area at a time, and wipe down with a clean rag, and get a grey look to the panel, and I've had some panels sitting for over a year.
As John said just give it a scuff down before paint and you're good to go.
1-ev.com 02-01-2012 10:12 AM
On Picklex20 website they said this is OK Picklex20 Manufacturer Home Page Metal surface preparation, steel pre-treatment.
My 2 c.
-Y.
saswata 03-02-2012 05:55 AM
Brownish color for Picklex 20
Sometimes a brownish color is noticed after drying of Picklex 20 coating. It is a part of the coating and not rust. The rust color is orange. Also, any whitish powdery residue on the surface happens when the excess Picklex 20 is not wiped off completely from the metal surface. There is no zinc phosphate in Picklex 20. Picklex 20 is a water based product.
Any question, call International Chemical products, Inc. (manufacturer of Picklex 20) at 256-650-0088. Web site: www.picklex20.com
1-ev.com 02-21-2015 09:35 AM
Also DO NOT SCRUB after Piclex appled
hemeoncdoc 04-25-2015 06:39 PM
I have had the same thing with Picklex. Definitely not rust! Areas that turned that color remaining stablem without developing rust. I had an area unprotected with Picklex, that area did rust but a darker red-brown typical rust color. The Pickles areas turn more of an orange color. Not sure about the chemistry there...
