-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   The Beginning of another project - 911 SC NB RS (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/707770-beginning-another-project-911-sc-nb-rs.html)
wachuko 04-10-2016 01:22 PM
Installed the calipers...
http://i151.photobucket.com/albums/s...psj8risfuf.jpg
I had installed the clip to the existing line thinking that the one that came with the brake kit attached to it... nope, that flexible line has to be remove as well...
http://i151.photobucket.com/albums/s...psjicgwkbd.jpg
http://i151.photobucket.com/albums/s...ps7c9qhogv.jpg
And since nothing has been easy on this car... guess what? Yeah, the lines would not come loose... hard lines would simply not come out...
It took a lot of WD40, praying and cursing (Yin-Yang :) ) and in some cases, cutting tools to get them out...
http://i151.photobucket.com/albums/s...pstpv4qwpy.jpg
But they came out in pieces at the end...
http://i151.photobucket.com/albums/s...ps8i6z1wv9.jpg
http://i151.photobucket.com/albums/s...psx3i1mea5.jpg
And good thing I had new lines just in case this happened...
http://i151.photobucket.com/albums/s...ps9ozfjyhf.jpg
New lines installed...
http://i151.photobucket.com/albums/s...pshz4ewoua.jpg
http://i151.photobucket.com/albums/s...psscqf9mbl.jpg
http://i151.photobucket.com/albums/s...ps8dzsvqdb.jpg
http://i151.photobucket.com/albums/s...psfoy2knki.jpg
http://i151.photobucket.com/albums/s...psrimyomyi.jpg
http://i151.photobucket.com/albums/s...pswmrmz5ih.jpg
http://i151.photobucket.com/albums/s...psylknpr6s.jpg
Another task almost done... yeah, forgot to buy ATE brake fluid :soapbox: so not able to bleed the system...
http://i151.photobucket.com/albums/s...pszkigobw6.jpg
Stickers installed on the Koni-orange painted Bilstein shocks
http://i151.photobucket.com/albums/s...pspahcucqb.jpg
And also tightened the bolts to the suspension arms at the chasis end...
wachuko 04-10-2016 06:48 PM
Well... turns out I did have a few cans of brake fluid... ATE Blue, Gold, and a Castrol SRF...
http://i151.photobucket.com/albums/s...ps0mduxww9.jpg
I was able to do the brake bleeding and finish the brakes... installed the old wheels and tires for now...
http://i151.photobucket.com/albums/s...psh8jvau4h.jpg
http://i151.photobucket.com/albums/s...ps6rlfwmio.jpg
Next, finish the wiring for the headlights, front turn signals, and horns...
Cairo94507 04-11-2016 04:51 AM
Car looks beautiful.
78-911SC 04-11-2016 06:10 AM
Wachuko as an experienced builder good move to reverse the trailing arm bolts. Things are coming together nicely.
wachuko 04-11-2016 06:52 AM
I could not find an answer when I was looking for what was the correct way to install them. So if there is anything I need to go back and change, please chime in.
I have done things so many times over and over due to my inexperience/mistakes, that I do not have an issue to go back and redo something if you see that it was done incorrectly.
I still need to torque the hub nut to specifications, that is why you do not see the cotter pin in place :)
http://i151.photobucket.com/albums/s...psfdzacbqn.jpg
SmileWavy
78-911SC 04-11-2016 11:50 AM
No you did it correctly. If the trailing arm has to come off for any reason you only need to take the nut off and pull the bolt out on the brake side. The factory installs them with the nut on the brake side but than you can't pull the bolt out because of the transmission. Most people cut the head off and than pull from the brake side. Just a pain to do with the tran in. Keep up the good work.
Luccia at Pelican Parts 04-20-2016 02:36 PM
This is looking really good. Love watching this build.
wachuko 05-21-2016 10:59 AM
I have been busy with things related to my children. Baby steps working with the car is more than an understatement...
A few weeks ago (might be months now...time goes by so fast) I had to remove the driver side lock mechanism since it was broken. To do that, the window rails/frame had to come out. Anyway... all that was pending getting a replacement lock and the time to replace it.
I did find a lock mechanism, from eBay, from a 1995 993. Turns out that it works perfectly in the older cars. Sorry about the lack of photos, I had my hands full trying to align the rails, then the glass came off the base, then the base came off the sliders, then...:icon501: anyway... I was able to put it all back together. Now I have a fully functional door with locks and everything. :jumper:
But I can't test the door window mechanism because looking in the trunk, I have no negative battery cable! :soapbox:
But hey... door is working and no longer have to keep it in place with a cord.
http://i151.photobucket.com/albums/s...ps0qep0gwj.jpg
Those are old bolts... I have new ones ready to replace those...
http://i151.photobucket.com/albums/s...psx6zd52d1.jpg
Door handle back in place...
http://i151.photobucket.com/albums/s...psszxbgqcb.jpg
Pork Chops 12-28-2016 10:47 PM
Progress?
Queefchief 02-12-2017 11:52 AM
Looking through this has me so motivated to finish my car! Love your work buddy! Looks damn good
heliolps2 03-14-2017 09:43 AM
Looking great , I hope everything is ok?
wachuko 08-11-2017 10:47 AM
Sorry guys... still have the cars but life gets in the way... no progress so far... just need time to get back to working on it...
chrisbalich 02-12-2018 07:52 AM
6 months update?
onboost 02-19-2018 03:22 PM
No truer statement, believe me I feel your pain! SmileWavy
heliolps2 03-13-2018 07:13 PM
just wanted to see what's up
wachuko 10-04-2018 01:54 PM
Not much... started working again on the 1967 912... that way I will never finish any of the three projects... :rolleyes:
wachuko 11-04-2018 12:57 PM
Between this nasty cold and the rain... not much done, but at least started working on it again.
Installed the new turn signal switch lever...
http://i151.photobucket.com/albums/s...psnc9zwapm.jpg
Installed Rennline driver side floorboard...
Installed driver side door panel. I had this waiting until I had finished the internal door lock mechanism... well, the lock was installed about a year ago and I never installed the door panel until now. Humm, now I remember, I was waiting to install the door mirror...that is why it kept sitting uninstalled... Anyway, I decided to install it now and I can remove when the time comes to install the mirrors. I still need to find again the template for the location of the mirrors... scare to drill holes in the wrong location, yikes...
And for the life of me, I can't find the door lock plug... ordered one from our host...
http://i151.photobucket.com/albums/s...psjjykk6rh.jpg
http://i151.photobucket.com/albums/s...psblnxl6ut.jpg
wachuko 11-04-2018 01:10 PM
It was nice sitting in it again... I have to finish my projects I so want to be able to drive these cars....
http://i151.photobucket.com/albums/s...psm7ix4noj.jpg
http://i151.photobucket.com/albums/s...psaepuopdj.jpg
http://i151.photobucket.com/albums/s...psk5aqcvmi.jpg
wachuko 11-08-2018 03:30 AM
I am working on identifying what this wire is for and where does it goes??
http://i151.photobucket.com/albums/s...ps8833c15b.jpg
Goes to this plug
http://i151.photobucket.com/albums/s...ps0jhsg21o.jpg
http://i151.photobucket.com/albums/s...psh0iwcwy6.jpg
wachuko 11-08-2018 11:08 AM
Mystery wire seems to be from the voltage regulator.* It goes into the DF terminal on the older alternators... researching... looks like that wire is not use in the newer alternators and it is just left like that and not connected to anything.
http://i151.photobucket.com/albums/s...ps51ac5cf6.jpg
http://forums.pelicanparts.com/uploa...1541707704.jpg
wachuko 11-20-2018 12:23 PM
Local shop was able to redo my fuel lines... they could not crimp to original specs so the ended up brazing adapters and making standard lines... With this done I should be able to install the engine and transmission back this weekend. Woohooo!
wachuko 11-20-2018 01:12 PM
Forgot the photos... SmileWavy
http://forums.pelicanparts.com/uploa...1542751443.jpg
wachuko 11-21-2018 09:26 AM
Could not resist... ordered a billet oil sump plate cover...
http://forums.pelicanparts.com/uploa...1542824527.jpg
wachuko 11-24-2018 08:27 PM
Engine is in!! Engine, transmission, headers, muffler... had to make some cutouts on the bumper to clear the tailpipes... used some trim I had to hide the cuts...
Now to work on the oil tank, oil lines, front center mounted oil cooler, etc.... closer, closer.
http://forums.pelicanparts.com/uploa...1543123461.jpg
https://i151.photobucket.com/albums/...psqazcvi9m.jpg
A couple more...
wachuko 11-25-2018 09:39 AM
Worked on separating the stock oil lines from the side loop/cooler... man those were stuck tight!!* Several cycles of heat and WD-40... at the end I placed the line on the floor and held the wrench on the fixed side while hitting the other wrench with a mallet.. broke loose without much force.* Now working on cleaning them. Using scotch brite pad and WD-40 (might switch to Simple Green if it works faster, need to test)...
http://forums.pelicanparts.com/uploa...1543171120.jpg
wachuko 11-25-2018 07:33 PM
One down, one more to go... and forget the WD-40... the best thing to use is Goo Gone!! Wish I had started with that and I would have gotten both done today...
http://forums.pelicanparts.com/uploa...1543206773.jpg
SmileWavy
wachuko 11-26-2018 05:41 AM
Man, wish I had been as organized as I was with the 912...
My 1967 912 Build Thread
When I took this one apart I did not organized the hardware in different backs/boxes... so guess what? Can't find squat! Had to order new bolts for the brackets that hold down the lines in place and also the two clamps needed...
1 - Rear Clip to Attach Oil Line Part #: 999-511-080-02-OEM
1 - Front Clip to Attach Oil Line Part #: 999-511-084-02-OEM
3 - Tapping Screw Part #: 900-187-032-02-OEM
This build is not like my 912 build... with the 912 I went overboard with every nut, bolt, hardware, etc. reconditioned... on this one, I just did the minimum... and now I am regretting it... eventually I will come back and do it all again and power coat and recondition everything nut and bolt... but for now, I just want to finish it and drive it!
Also had to order a few more items to finish the clutch install. The small cir-clips and hardware on the outside of the transmission... Also ordered a few more things to get the oil tank ready for installation. I need to finish cleaning it and put a coat of paint on it (was not going to risk having it powder coated)...
Engine Oil Tank Support Bracket Part #: 901-501-930-22-OEM
Washer / Spacer for Oil Tank (2 per car) Part #: 901-107-661-00-OEM
Oil Tank Mount Washer (Plastic with Recessed Center) Part #: 901-107-693-01-OEM
Oil Tank Mount Washer (Plastic with Raised Center) Part #: 901-107-692-00-OEM
Intermediate Layer Part #: 901-501-909-20-OEM
Oil Cap Seal Part #: 930-107-272-01-M127
Fuel Level Sensor Gasket Part #: 914-201-891-00-INT
Oil Tank Gasket Part #: 911-107-192-03-M253
Manual Trans Shift Rod Support Boot Part #: 911-424-294-00-INT
Helper Spring Upper O-Ring, 7.3x2.4mm Part #: 999-701-209-40-OEM
Clutch Helper Spring Pivot Washer Part #: 900-234-502-01-OEM
Helper Spring Bearing, 2 Req Part #: 999-201-212-00-OEM
Helper Spring Pivot Pin Part #: 915-116-624-00-OEM
Helper Spring Spacers Part #: 930-116-617-00-OEM
Assembly Lower Cover Part #: 900-036-016-02-OEM
Helper Spring Upper Circlip Part #: N012-408-2-OEM
Clutch Release Bearing Guide Tube O-Ring (40 X 1.5 mm) Part #: 999-701-359-40-M30
Throw-Out Lever Shaft Lower Circlip Part #: N-012-418-1-OEM
Throw-Out Lever Seal Part #: 915-301-139-00-M30 - I probably have 4 of these that I can't find!! :mad:
Engine Cylinder Head Nut Part #: 901-104-382-02-INT - This is for the top bolt on the starter
wachuko 12-01-2018 08:33 AM
Removed stock sump plate cover. Remove studs.
http://forums.pelicanparts.com/uploa...1543685274.jpg
Installed new studs at the right length... used blue Loctite
Eye candy...
wachuko 12-01-2018 12:51 PM
Installing front mounted Elephant Racing oil cooler...
http://forums.pelicanparts.com/uploa...1543701059.jpg
wachuko 12-02-2018 01:10 PM
Second oil line cleaned and installed... still waiting for the bracket bolts to mount those...
Installed thermostat and lines... realized that the second line is not the correct one, that is the old line for the newer oil lines and I had backdated mine... and of course, can't find the correct line in the pile of parts that I have... so ordered a new one.
Oil tank reconditioned. Ordered a new oil level sender since the one in there was giving erratic measurements when I tested it... and now is the time to change all this...
http://forums.pelicanparts.com/uploa...1543788552.jpg
wachuko 12-02-2018 06:49 PM
Found the oil line! All set... tank to go in as soon as the rest of the parts get here. SmileWavy
http://forums.pelicanparts.com/uploa...1543808955.jpg
jjeffries 12-08-2018 09:14 AM
Wachuko...beautiful work. Great vision.
I may have asked this before, but what kind of floor tile is that...ceramic or porcelain?
How's your Fiat? Best, John/CT
wachuko 12-08-2018 05:11 PM
John, tiles are porcelain. Stronger and have handled dropping tools, hammers, metal grinding, etc. without issues. Best part is that I got them at local Home Depot for $0.78 per tile. I even drilled through them when installing the lift... pretty strong. Did the install myself over two weekends.
I really wanted a checkered floor...but that was outside of the budget.
Fiat is in need of a new home...have not had the chance to work on it. Wife is pushing me to get it on Craiglist... :(. Ignoring the request has worked so far...hehehhehe
Focus right now is to finish the SC... replace the transmission and rebuild the steering rack on the 964... the 912 is waiting for a friend to finish the body work...
SmileWavy
wachuko 12-08-2018 05:41 PM
Received the oil level sender today... installed!
http://forums.pelicanparts.com/uploa...1544323014.jpg
Tank now installed:
http://forums.pelicanparts.com/uploa...1544323232.jpg
wachuko 12-08-2018 05:44 PM
Removed rear bumper to install some heat shield material... hope that is enough for the muffler to not damage the bumper...
http://forums.pelicanparts.com/uploa...1544323393.jpg
Too many family related tasks that needed to be done today... could not get anything else done with the car... will continue tomorrow. SmileWavy
wachuko 12-09-2018 07:45 PM
Almost done with the oil system... had an email exchange with Chuck from Elephant Racing, to make sure I had the front lines installed correctly. So that is done. For this I had to take the front bumper off so took the opportunity to install the turn signals.
Installed the bumper back and also installed the lower lip... less stuff on the floor and more on the car...
http://forums.pelicanparts.com/uploa...1544417112.jpg
wachuko 12-10-2018 06:50 PM
Finishing the clutch release lever assembly with new spring, bearings, washers, shaft, etc.
http://forums.pelicanparts.com/uploa...1544499891.jpg
A few more
