lacqure paint
i cant even spell .it so why am i trying to use it??? i race go karts and am really picky about how my kart looks each week. race to win and don't always start up front. so my fiberglass gets torn up. i guess i have had good luck up till this past weekend ( a few tears nothing ripped off) patched up and retouched with duplicolor had really I'mpresIvexresults. luck ended last weekend . after the repairs looks like a
jigsaw puzzle or a quilt . more than a rattle cans worth. bodywork is really smooth (was taught about wet sanding with a squeegee at an early age ). Ive got a qt of my color and a gravity gun (mountain) my question involves fiberglass and lacquer what is a good and cheap sealer for the glass that the lacquer wont wrinkle and cant remember how much to reduce the lacquer for spraying . why cheap? 6 races left and i want to be sharp for all 6 my class rubs pretty hard color is black. next year I'm going to white!!!!new glass body molded in white .thanks for the advice this forum is great |
dkbautosports.com
my friend don't worry about spelling i can't write or spell worth a dam .
lacquer is a hard product to work with it wants to lift the metarial /finish that is under it when you spray a new coat or two down . once you decide to use lacquer you will then have to use it all the time for every product you dut down on the panel . so that would be your primer , sealer , and top coats would all have to be of a lacquer base product . ok so heres what you have to do : you have to find the product on the nose panel that is giving you the lifting broblem . is it a primer you used ? many times that's what it is because the primers you buy in a spray can tend to be of a enamel based and you can't mix lacquer and enamel or it lifts . you how every can spray a enamel over lacquer but not the other way around . so people tend to do ok untill they get to spraying the new fresh top coat of lacquer over the enamel primer they put down . so if it's the primer you will have to strip the primer off the nose piece . get your self a little electric palm sander and some 80 grit paper and strip off ALL the problem product from the panel . it all has to be stripped off ! from the 80 grit change the sand paper to 220 or 240 and sand every thing again to get rid of the 80 grit sand scratches . then once you have it all the problem finish stripped . get some lacquer primer pepboys sells it along with summet , jegs and speedway . just be sure it's lacquer . then as a test spray a little area with the primer . to be sure your not having any more lifting problems . if your not then spray the rest of the nose panel . the trick to lacquer is do not pork it on spray more but lighter coats when it comes to lacquer . if some thing with lacquer wants to lift people tend to try and pork on more heavy coats this is wrong you want to spray very light coats . it's the wet solvents that is wanting to lift the metarial underneath so dry is better . once its primed you then let the nose panel sit untill it's nice and dry and sand it with 400 to 600 wet is best . if you sand thru a little area or two when your prep sanding the nose panel after you finished sand spot in the brake thru areas with more primer . you don't have to reprime the hole nose just the brake thru areas and then resand the areas that were primed . dry the nose panel and then tack it off with a tack reg . they sell them at any auto part store like pepboys . then spray the ose with the color or colors of your liking . the lacquer you would want to buy is duplicolor's paint shop coatings ( primer base color and clears ) are ready to spray so you do not need to mix any lacquer thinner into them . you can buy a cheap thinner at places like home depot to wash out your spray gun but don't try and using it to thin lacquer paints as it's a wash thinner not a tinnner made to reduce paints . always cap the can of paint when your not using it to keep it the vocuosity the same so you can spray it . |
thanks ill let you know how this turned out
ok finished installed crtiqued by teammates raced scratched up will be touched up latter this week i use the product as abase clear how do i do a spot repair? the overall was easy .although i couldnt get an orange peel free finish . more wetsanding than i wanted to do. think the environment was thecreal culprit there ,it was a cool damp night . the duplicolor just wouldnt lay out for me no runs thoug just too much opeel .
can i do this as a spot , do my body work ,prime the work area ,not the whole panel,color the primer . clear the color ,then hit it with blender if necessary. tell mee if i 'm off track |
dkbautosports.com
spoting in lacquer is ez . it may take two or 3 times to nail it down but all and all it's easier than other finishes .
once your body work area is all set and ready for color and clear sand the area your looking to paint with 600 to 800 grit wet paper . you will need some lacquer thinner to melt the clear blean into the old clear . so go to the store and get some duplicolor lacquer thinner . now spray the color over the area were you want to cover the damaged area and walk the color out just a little so your not stopping in the same place with each coat of color . just kind of dust out he edge of the color coat onto the old clear . then do the same with the clear walk that just past the area were you did the color coat and again kind of just have a little dusted in area from the clears over spray . let it set up as you clean out your spray gun then with 9 parts of just thinner to 1 part of lacquer clear mixed together . spray a light melt in coat of your mix over the edges of the blead area . don't spray to much thinner at once or it will just run on you light coats just to melt on the over spray edge . all your looking to do with the thinner bleaning mix is to soften the old clear as to give the new clear some thing to bite or melt into . if it looks a little pealy it's ok you should be able to buff it with some compound after it's all dry . just sand it with a piece of 1200 or 1500 wet paper and buff a shine back into it . |
