Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
Rusty Nuts and Bolts? Make Your Own Super Rust Penetrant!
Found this on the net.......
Since its invention in 1953, WD-40 has been the go-to solution for many household and garage problems. Over the years, other companies have come up with their answer to WD-40's penetrating properties such as Liquid Wrench and Kano Kroil. Others have tried their own home-brewed concoctions in the never-ending battle against rusted nuts and bolts.
Our favorite is a 50/50 mix of acetone and Dexron/Mercon Automatic Transmission Fluid.Simply mix one part acetone and one part ATF in a re-fillable spray bottle and go to town. The idea is to thin the ATF with the acetone so it will penetrate and seep into and between surfaces. The acetone will evaporate, leaving the oil to do its job. Because the acetone evaporates so quickly, it's a good idea to mix this in small batches.
Skeptical? We were too. Then we did some poking around on Google and found that in the April 2007 issue of Machinist Workshop Magazine, they performed subjective independent testing of penetrating oils using a single steel bar with 1/2" x 20 nuts torqued to 50 ft/lbs and treated with a 10% salt water solution that was allowed to rust.
Listed are the chemicals tested and the respective required removal torque:
None 516 pounds
WD-40 238 pounds
PB Blaster 214 pounds
Liquid Wrench 127 pounds
Kano Kroil 106 pounds
50/50 Acetone / ATF 53 pounds
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 11-27-2013, 02:30 PM
Bird. It's the word...
Fishcop's Avatar
Nice tip, thanks Kevin.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 11-28-2013, 03:38 PM
LakeCleElum's Avatar
I read something similar.....What I recall: 50/50 mix of diesel and AFT fluid....I now use that in a spray bottle.....
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 11-28-2013, 10:43 PM
hemeoncdoc
I read that same article and used it. It must be the best lubricant that I have ever used to loosen bolts and nuts. The only bolt that I couildn't get out on a complete disassembly was an impossibly corroded pedal cluster bolt. This, on a 1968 911. Be careful with the reusable plastic spray bottles, as this solution will eventually attack the plastic and risk a leak, so make up only what you will use in a short time. Also beware - HIGHLY flammable.
Too many hobbies, too little time...
Old 01-18-2014, 07:35 PM
