Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Correct Colour
Hi, I've started stripping my 68'S' for a total rebuild. Throughout the years the car was given a wide body kit but, for the time being it will stay that way.... Going back to the narrow arches is beyond my current budget. Although, I would like to know the original colour of the car. The car has been painted over and over and never got a proper paint job. How can I, through the VIN, find the original colour of the car?
Chris
Old 11-30-2013, 10:55 AM
Also, anyone knows what the measurement from the inner panel to the edge of the rear arch on the 3.2 SC stands at? Mine stands a 14". I Managed to find a rear half which I was thinking of buying to use in case I remove the wide GRF flared arches and replace with the SC.
Old 11-30-2013, 11:13 AM
non-whiner
mreid's Avatar
The 3.2 is not an SC, it is a Carrera and is wider than your stock 68. If you still want the Carrera flare width, I'll sell you the ones from my 84 that I cut off when I welded on turbo flares (what you currently have) for $100 plus shipping.
"Too much is just enough."
Old 11-30-2013, 12:48 PM
pors1968's Avatar
For the color it should be a plate on driver post where is your hinges.Ifnot take off the sunviser and you should some original colour
Old 12-13-2013, 07:37 PM
