Need advise on chrome removal
Hi I have a set of chrome fuchs, I want the chrome gone anyone here
please help, thanks
"IGNITION LEFT OF STEERING" Alex |
Alex,
Rims must be soaked in acid then bead blasted, Just had set done in Hayward, Ca. 75.00 per wheel w/o primer & paint. Regards |
yah thanks EPA just shut down the guy here in Jersey, I have no one else
to go to. thanks.. Regards
achrome plateing shop can strip them for you i do not know the cost the llast time i had a bumper done they did not charge me anything
jerry
JM Motorsports Custom Paint & Bodywork 81 911 SC ,black 73 914 V8 LS1 83 Audi Ur-Quattro,black |
dkbautosports.com
every time I had to have chrome remove I just sent it to the chrome shop .
the shipping have cost more then what the shop would charge us to remove the chrome . the acid will only take the chrome off not any of the other metals the chrome shops use under the chrome . that has to be sand blasted ! on aluminum the grit of the blasting media will ruff up the aluminum so much you will be hating life sanding the aluminum smooth again for the new finish you want to put on the wheels . if you plan on buffing the aluminum at all for the shinny buffed aluminum look acid and blasting is not what you would want to do . |
thank you 962
Alex I'm in the same boat. I have chrome Fuchs and want them stripped and redone with black centers. If anyone knows anyone in Ct please let me know.
dkbautosports.com
203 630 1046 I think is there number but check to be sure . very high quality work I have never been disappointed with all the work they have done for us in my shop . |
