Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Orig rear fenders need to replace bad flares for 71
thus car has poorly done flares made by had ,they are terrible. I need to make this car right and need to weld in appropriate rear wheel longs. Need cut for just in front on access torsion bar just below 1/4 window and 6" or so beyond end of wheel pong
Thanks for assistance
Frank
Old 06-01-2015, 07:09 PM
Frank are you looking for quarters??? If so I have a set from a 74 I can offer you or I have just the flare.
Can you provide a pic of what you are looking for?
Old 06-02-2015, 10:54 AM
Thanks for note, just need the flare with some more metal just in front of the torsion hole and , just past the rear flare. Let me know
Frank
Old 06-03-2015, 08:08 PM
Frank,
I just sent a reply to your PM. I will post some photos later today of what I have. As you will read in my PM, the flare itself I am relatively sure is the same for a 71-74 the issue may be the length of the car from the front of the flare to the rear of the door. At some point Porsche changed the length of the 911, as I recall it was 1966 but I may be wrong as something else tells me it may have been 1972 at the same time they added the oil fill door on the right rear fender. If that's the case there may be an issue between the flare and door that could change the torsion tube hole location. I think the length changed between the torsion tube hole and the door but again I am not certain. Hopefully someone will chime in and clear up the issue.
Don
Old 06-04-2015, 04:37 AM
1/4 panels
I sent you a bunch of photos of 71 and dimensions taken from my 73 let me know progress
Frank
Old 06-07-2015, 06:34 AM
Hi Frank,
Check your email to see if they sent I don't have an email from you. I checked my spam and trash incase it accidently was deleted. Send me a PM and let me know what email I am looking for please. Also sorry about the delay in getting pics of the flares up. I forgot my camera.
Don
Old 06-07-2015, 07:16 AM
1/4 panels/flares
i sent from my I-phone , will check and let you know
Frank
Old 06-07-2015, 05:24 PM
Rear 1/4 panel
per porsche parts catalog the 70 to 73 is the same. Seems 74 would be different .
Also tried to resend , need e-mail to get to you
Frank
Old 06-08-2015, 11:46 AM
