How much time between epoxy primer and 2k
The data sheet says not to sand epoxy primer so how much time do you have before you have to apply the 2k primer.
dkbautosports.com
you only want one coat of epoxy primer .
then let it flash off it should be about 15 to 20 minutes but temperature has allot to do with how long some thing takes to flash off . the TDS should have flash time in it . not knowing what primers you using I'm just guessing at flash time . |
