Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
fhernand's Avatar
Engine Shroud Restoration
I'm looking for ideas on a method of restoring my red engine shroud for my 67. I have already taken care of the cracks, scratches etc., now I want to bring back the red look and yet still keep it's original look. What are you guys using?
VINTAGE SPORTSCAR RESTORATIONS
www.vsrestorations.com
freddie@vsrestorations.com
Freddie Hernandez
(541) 535-3304
Old 06-27-2008, 11:25 AM
Retired Member
Charlie V's Avatar
I picked up several different small rattle can of red touch up paint from the local parts supply store. I tried 3 cans before I had a good colour match. The rest were returned for refund.
The usual paint prep, primer and top coat. Turned out well and seems to be durable.
Before.....
After.....
I believe it was a Toyota colour.
Good luck.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine.
Old 06-27-2008, 08:45 PM
SP2 SP2 is offline
SP2's Avatar
I am curious to know the answer too. I know that the ones I have seen painted red don't look so good. Everything else can look good painted on the engine, except the shroud in my opinion.
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 06-27-2008, 08:46 PM
SP2 SP2 is offline
SP2's Avatar
Uhh, hard to argue with that photo.
James
1981 911SC Wine Red
Old 06-27-2008, 08:47 PM
fhernand's Avatar
I found this method which I will be trying today. This is more like what I'am trying to achieve without the use of paint. I will post before and after pictures of the project and see what you guys think.
Freddie Hernandez
(541) 535-3304
Old 06-28-2008, 07:16 AM
fhernand's Avatar
Here is the before and after picture of my engine shroud restoration. The only thing I did different was that I added two coats of clear to bring out the color. The article was helpful.
Freddie Hernandez
(541) 535-3304
Old 07-01-2008, 06:15 PM
I have done Unimog dog house covers, which are fiberglass like the shrouds. Wanting that factory look without painting, what I have done was to wet sand the whole thing down, which brings back the color some and then spray with a semi-gloss clear. Makes it look like its brand new! Should work for a engine shroud as well.
Von
http://vonsmog.com
73' 911T Coupe, 76' 911S Targa
73'& 80' Mercedes Unimog DoKa
59' Austin Healey 100-6
Old 07-06-2008, 09:11 AM
al lkosmal's Avatar
shroud
I'm with Von,
Wet sand, followed by rubbing compound and shoot with clear. Here's my 37 year old , 71E shroud, prior to the clearcoat.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 07-13-2008, 02:58 PM
fhernand's Avatar
Here is the final finish on the shroud. I was very happy with the process.
Freddie Hernandez
(541) 535-3304
Old 07-27-2008, 07:49 AM
robmog's Avatar
nice!
i wonder how the clear will hold up to the engine's heat?
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 07-27-2008, 02:59 PM
fhernand's Avatar
Dupli-color makes a spray can enamel clear that is high temp rated. I have used this clear before on calipers, exhaust, etc., so far it's held up very well.
Freddie Hernandez
(541) 535-3304
Old 07-27-2008, 04:52 PM
not stock at all but acrylic urethane without any primer has held up real well for over 8 years and 80k miles.
It darkened a little but no lifting.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-28-2008, 10:36 AM
Reviving an old thread - Has anyone tried the dye method on a shroud that's been sanded aggressively? Mine has. Also, I have a least one crack to repair, will the dye work on the clear cloth and resin I use for repairing the crack?
1971 Light Ivory 911T - Gretchen - sold
Looking for Engine # 6114097
2010 Cayman
Old 11-01-2016, 07:47 AM
Clean, degrease and wipe on some Penetrol in the paint department of any hardware store. It is a petroleum based paint conditioner. It is somewhat like a clear coat but not a paint. As the name implies it will penetrate the fiberglass and create a satin-ish sheen. We use Penetrol on UV damaged fiberglass boats. You can wipe on multiple coats. It will also dry to a hard shell.
Old 11-09-2016, 07:53 AM
