Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
dkbautosports.com
962porsche's Avatar
little patch
1969 camaro has a rust hole in a strange place they don't tend to rust .
i cut out the area to find a mouse nest inside the rocker
i took the piece i cut out and traced it out on a piece of sheet metal using a sharpie marker.
the kerf of the cut off wheel blade is just about the width of a sharpie marker so when you cut out your patch piece cut it on the outside of the sharpie marker line .
coat the back side of the patch piece with weld primer . when it comes to using weld thru primer you do not need a heavy coating of it a thin coat is all that is needed . to much and you will get a bad weld . let the weld primer dry for a few hours to let all the solvents evaporate . i personally like brushable weld primers more then spray types .
hole the patch piece in place i tend to use a magnet for this .
place a tack weld and let it cool ..if you feel any heat do not place your next weld until it's cooled back down . work your welds spreading them out around the patch piece .
once all your welds are done it's grinding time to smooth out your welds . this i do with a 24 grit flap grinding wheel . the reason i like to use a flap wheel for grinding welds is they do not build the heat a none flap wheel does .
when your finished you should need little to no plastic body filler .
Old 11-07-2016, 04:53 AM
Tom '74 911's Avatar
Nice write-up 962porsche!
Here's some little pieces I made up to fill in some holes in the floor pan & rear seat back area from a previous owner's roll bar I think. The holes were a little too big to fill in w/a MIG, although I probably could've made that method work too. I'm not a pro/for profit shop, so I don't always chose the fastest method, but usually the one I'd either like to experiment with or that I'm most comfortable with.
Kind of tedious to cut out a bunch of pretty small circles, weld a short piece of TIG rod onto each one so I could hold them while MIGing them into place. I didn't take finished pics yet...
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 11-08-2016, 04:24 PM
dkbautosports.com
962porsche's Avatar
those little holes are a PITA aren't they .
to make the little round hole patches like that using a press punch works pretty well .
Old 11-09-2016, 02:26 AM
Puma's Avatar
On the same line, what's the largest hole that can be welded by backing with a piece of copper and filling in?
Thanks for showing us how to do larger patches. I've got quite few spots to do on my car.
2001 986 S
Old 11-10-2016, 06:05 PM
dkbautosports.com
962porsche's Avatar
i tend not to use a backer for welding up holes bigger then 1/4" or so at that point the hole becomes to large and a patch piece would get used .
Old 11-11-2016, 03:08 AM
Puma's Avatar
Thanks for the info!
2001 986 S
Old 11-11-2016, 07:36 PM
This might be a possible technique for my quarter edge instead of replacing the entire panel. Thanks!
Old 11-29-2016, 12:42 PM
