I'll race for food
help me id this 1988 pearl white please
I have an 88 with in pearl white that I need to do a little touch up. the color code is PEARLGLANZEFFEKT. my painter tried to look it up in the system and the only thing he found was PEARLGLANZWEISS..... i have a feeling those are not the same colors. Can anyone confirm this?....Can anyone suggest a way of finding the original formula.
Thanks in advance Radu ![]()
Radu '82 SC black on black "The Beauty" 3.8 RSR GT2 track/street "The Beast" www.octanegallery.com |
less I know,more I learn
Ask your painter if he can mix you a small amount to spray on something & see if it's a close match. Bright metallic & pearls are more difficult to blend in touch ups & repairs to old paint. You'll notice a difference in color & shade from new paint to old paint. Even if you have the exact same paint that was used on the car. Anyway some paint companys have the same code,color & different name. I restored a 76 benz & had a digital scanner used to match paint. The color was bang on. Dark green,Dupont Chroma base clear. Cheers
Raymond |
1.367m later
Pearl White Effect. Standard Porsche color. Easy to match. The 947 9 3 is the actual color code
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
I'll race for food
thanks Kevin, somehow my painter only found PEARLGLANZWEISS in his computerized system. Is that the same as PEARLGLANZEFFEKT?
1.367m later
I'd look at the paint code number and not the name to determine if its the same color. Not knowing what data bank he's looking at I couldn't say.
dkbautosports.com
being the ex Porsche's dept head of coating for years and because of this I have all the info the factory would have I was getting so swamped with emails and PM's about peoples car colors .
I stopped giving out info to people about there cars colors . because of the very short production run of the 947 white pearls on the 928's the paint manufactures tend to drop the color code listing from there up dates of color formulas . you code 947 happens to be one of them that was dropped . the code you have to now look for is L0A9 under VW/ Audi as it was used on the (water cooled cars) built in the VW then the Audi plants . you could also use the number 0A9 under Porsche for air cooled cars . all codes 947, 0A9, L0A9 are all the same colors they are called different names with different code numbers but are still all the same colors. if the shop is using BASF they will find there are 3 different variants of the color so finding a match should be very ez for them to do . |
OK, resurrecting this old thread. I have a paint code ID plate that shows 947-9-3, however it is an older one. I don't see pearl white offered anywhere on the earlier cars. I found this tag mixed in with a 1964 356C that I just picked up. The 356 appears to be Bali Blue. I was hoping this was the ID plate for it but all I'm finding is Pearl White... which was not offered in 64' Any thoughts or insite on this?
Brgds, Peter Baldauf 1967 912 1988 911 vert 944 TS 1969 911 E 1956 356 Conti 1983 911 SC |
