Removing deep rust
What is the best way to remove all rust from the doors? I have been using 24 grit paper on a grinder. this has cleaned up most the rust, but, I still have deep pits that won't clean up.
thanks, Shane |
How deep are we talking? Rust is like cancer - you have to 'cut it out' or it will spread...
http://www.pelicanparts.com/ultimate/frown.gif -Wayne |
Deep surface rust pits. The kind you will never get out with a grinder or sander. I was told to try muriatic acid. then coat with POR-15.
Use OSPHO aka Metal prep. OSPHO can be puchased at True Value. Metal Prep is at the Welding supply store. Apply with a brush and let dry,then prep and paint. Steve
| All times are GMT -8. The time now is 11:58 AM. |
