Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
pjv911's Avatar
Send a message via AIM to pjv911
Help identify this rear brake drum
I am going through my attic and found this drum. I don’t recall what it came from.
I searched google using the #’s stamped and came up with nothing.
Maybe someone here can assist?
The numbers are 15919 3110.4
It’s a rear drum. I’ll try to get pictures uploaded. It’s been a few years since I frequented this forum. I appreciate any help with this.
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 09-26-2021, 10:33 AM
pjv911's Avatar
I’m guessing it’s not easy to identify?
Old 09-26-2021, 08:58 PM
As far as measuring, the most accurate way is with the drum/hub removed from the axle. Measure across the diameter of the inside of the drum and the depth of the swept surface of the drum.
liteblue.usps.gov
Old 10-25-2021, 01:53 AM
not easy without pics. measure the inside as stated above. 280mm is 1953 thru Bt6. there are some subtle differences between pre A and A drums. B drums have many cooling fins
Old 10-26-2021, 04:07 PM
