-   Porsche 356 Technical Forum (http://forums.pelicanparts.com/porsche-356-technical-forum/)
-   -   timing w/ an -022 dizzy (http://forums.pelicanparts.com/porsche-356-technical-forum/1107868-timing-w-022-dizzy.html)
npresley 12-01-2021 04:23 PM
I have an -022 dizzy on a '61B motor. I have set the static timing at TDC, but I am seeing close to 37 degrees at 3400rpm. Does this sound correct? It doesn't ping, and it pulls well off of idle. Thoughts?
Prsh356 12-02-2021 05:53 AM
How old is your 022 ?
npresley 12-02-2021 05:57 AM
not sure
npresley 12-06-2021 07:06 AM
I have word that the distributor was rebuilt by Glenn Ring around 2008.
wdfifteen 12-27-2021 11:47 AM
30 to 35 @ 3000 rpm is what I set all my timing at. I would have the distributor looked at - or set the timing at 33 @3000 rpm and adjust the carbs to get a 900 rpm idle.
Kling 12-28-2021 04:15 AM
Thank you for sharing this i got my doubt cleared. keep supporting.
Target MyBalanceNow
