Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
timing w/ an -022 dizzy
I have an -022 dizzy on a '61B motor. I have set the static timing at TDC, but I am seeing close to 37 degrees at 3400rpm. Does this sound correct? It doesn't ping, and it pulls well off of idle. Thoughts?
Old 12-01-2021, 04:23 PM
How old is your 022 ?
Old 12-02-2021, 05:53 AM
not sure
Old 12-02-2021, 05:57 AM
I have word that the distributor was rebuilt by Glenn Ring around 2008.
Old 12-06-2021, 07:06 AM
wdfifteen's Avatar
30 to 35 @ 3000 rpm is what I set all my timing at. I would have the distributor looked at - or set the timing at 33 @3000 rpm and adjust the carbs to get a 900 rpm idle.
Old 12-27-2021, 11:47 AM
Thank you for sharing this i got my doubt cleared. keep supporting.
Target MyBalanceNow
Old 12-28-2021, 04:15 AM
