Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Question difficulty turning over engine
I have a 64 356SC. SC engine ran but fouled plugs badly... time to rebuild. Put known good C engine in; (stored indoors 4 yrs. but oiled every year and turned over by hand). The C engine has good compression (9.5) compared to the tired SC engine when turned by hand, sparkplugs in place, carbs removed. Starter can not turn C over fast enough to start when plugs are installed. Starter & bushing new 100 miles ago, and it turns over C engine very fast without plugs in. So no apparent conflict with valves hitting pistons. I have oiled cylinders thru plug holes. I can rotate by hand: slow with plugs in and noticably easier with plugs removed. When I use starter, it rotates very slowly but will fully rotate engine; and without plugs it spins very fast.
Any suggestion at to difficulty spinning engine with plugs in place?
Old 01-28-2024, 12:46 PM
6V or 12V?
Old 01-29-2024, 12:52 PM
6v system. Battery in excellent shape, just had shop load test it.
Old 01-30-2024, 06:43 AM
BTW. #0 GA wire to battery with new clamp on connector. My coil is disconnected.
Old 01-30-2024, 06:45 AM
Sounds like the starter motor is down on torque. I've got several 6V that test good, spin fine but low on torque when on an engine. Stoddard sells a 6V high torque starter that will spin anything.
Old 01-30-2024, 12:50 PM
Great to know. I'll pull the starter and have it tested for torque. I assume they can do a load test on it. Hopefully. I'll also lube the bushing while I'm in there.
Thanks for your input. I'll let you know how it turns out.
Old 01-30-2024, 03:24 PM
Lash
Make sure the battery negative cable connected to frame is clean and no paint where cable connects. Check all cable connections.
Lash
1963 356 T-6 Normal Coupe
1972 911 T Coupe ..... Sold
1972 911 S Targa ...... Sold
1980 911 SC Coupe Weissach
Old 01-30-2024, 05:50 PM
