Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
three56a's Avatar
Send a message via AIM to three56a Send a message via Yahoo to three56a
Question engine won't idle? why?
started the 57a after 3.5 years and i got it started but it would not idle. had to coninuously use the carb.
does anyone have any idea why this would happen?
thanx three56a
Niece
Old 12-16-2001, 03:16 PM
Did you change the fuel?
Are the fuel lines in need of changing?
What are the cicumstanses that the car was left and not run for 3.5 years, knowing this info may bring some insight into helping you with your problem.
Regards,
Kelly
Old 12-16-2001, 03:21 PM
three56a's Avatar
has been going thu a very slow total body restoration and
just got painted. so 57A was taken a part including the gas tank.
so gas tank was refurbished (cleaned up and painted)
fuel cock has new washers ... but no lines were replaced.
as i was starting the the cock was always on RES.
i did see the gas going thru the filter. but... never did idle.
I have to finish the dash so i could not tell what rpm it was going at.
thanx 57A
Niece
Old 12-16-2001, 03:59 PM
Senior Member
Hello
Where to start ?
Check your ignitiontiming, the valve play and then check the carbs.
Floatlevel, clean jets, syncronize.
Grüsse
Old 12-17-2001, 09:29 AM
