Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
VW motor into 356 B T6?
I've inherited my mothers "Honeymoon Special, 3 Generations". It is in need of a motor rebuild. I intend to put a VW motor in until the original motor can be rebuilt. What problems am I going to encounter? Thanks. Russ
Old 09-26-2005, 02:45 AM
id10t's Avatar
Fitting the sheet metal, maybe the clutch setup, maybe generator/regulator voltage
Old 09-26-2005, 06:07 AM
It should not be that hard. Finding the right clutch, pressure plate and bearing might require some research. Is a T6 6v or 12v? If its a 6 you can use 6volt VW stuff or convert it to VW 12v. None of this is going to be hard to do. Fitting the sheet metal can be accomplished with a cardboard mock-up. Or you can give me a deal on your T6.
Bryan
Old 10-05-2005, 07:48 PM
Waz356's Avatar
Standard T6B would be 6v.
Cheers, Warren
'61 356B Coupe (Kate), '62 356B Cabriolet (Hannah)
'74 VW Kombi (Rex), '84 928S (Louise), '98 996 Cabriolet (Babs)
Old 10-05-2005, 08:46 PM
There is a guy with a 58 for sale on 9/21, the car is sold but it had a VW engine. his handle is BLKIXXI. Ask him what he used.
Old 10-10-2005, 10:27 PM
