I am trying to connect my fog lights. Car is a 62 electric sunroof coupe. This moves things around on the fuse panel just a bit.
The original fog light switch wires are present and unused under the dash. I would like to use them if possible. The switch is there. I have been unable to locate a fog light relay but have found another horn relay that looks like it can substitute for the fog light relay? It has #85, 86, 87 terminals and 2ea 30/51 terminals. The white with gold stripe goes to #6 fuse terminal. The yellow with white stripe would go where on the relay? I am not concerned about the high beam interlock. It is ok with me for the fog lights to stay on when the high beam is on. Will this work? If not can I go direct to the fog lights without use of a relay? Or?? Thanks a bunch for your assistance.
___________________ Steve- 62 356 S90 Sunroof-sold 11/16 ![]() 73 911 No longer Targa-3.2L Running GT4 88 Carrera G50 sold 2019 2015 Cayman GTS |
Get Joe Leoni's 356 Electrics diagrams/manual - best $75 you'll spend. www.356electrics.com
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
My memory sometimes gets weak.
I am ordering the book! Thanks
