Headlight problem
on my Volkswagen Jetta both my headlights are out
The headlight switch shows high beam but no headlights when I switch between regular and high beams I am assuming the bulbs are burned out. I tried to put in a set of high intensity bulbs and one did not work and now both are out Any ideas what I should check |
Check your fuses.....oh and this is a 356 Porsche site.
Good luck, Chas. 356 912
Thank you, Your Welcome! and Best of Luck.... Chas. 356912911 |
