window regulator problem
I am putting my car back together after a total strip. I pulled off the chrome frames on the doors for the bodywork and paint job. Before I reinstalled the chrome frame I replaced all the felt and channels around the window. Now, when I roll up the window it tries to move backwards (towards the rear of the car). Doesn't want to go up or down but will do so if I push/pull it with my hand.
What did I do? What did I screw up? How do I fix it? Thanks all, Greg |
Need more info but are you sure it's bolted in at all areas? I just did both doors on a 63, do you have a schematic ? that would help.
Chas. 356 912 |
| All times are GMT -8. The time now is 07:21 AM. |
