Help identify these 356 items
I have a few leftover items from a 1963 coupe restoration and figured to list this stuff on ebay to get rid of them. Can anyone identify these latches. Front, rear. upper, lower?
Kurt Williams ![]() ![]() ![]() ![]() ![]()
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
287 views and no help ? Im glad Im a 911 guy.
Kurt Williams
Front and rear hood release latches. Looks like part of a window winder I'm not sure about the first pic. It looks familiar though it could be part of the door release mechanism.
63 356 So Called Outlaw 76 930 |
Ive found out that the 2nd one down is a inner door release. On the ones you identified which is which and which is the mate. Ive pictured two female latches and a 2 arm looking thing. Also the yellow 90 deg tab.
I'm at work right now. I'll look tomorrow and get back with you to make sure. I think the bottom pic is the front hood release and the one up from it the rear deck release.
Just a big kid really...
Hey Kurt,
Pic 1 - hand throttle Pic 2 -you already know Pic 3 - engine lid catch (on engine lid itself) Pic 4 - AT2/BT5 bonnet catch (you need the pin on the bonnet for a mate) Pic 5 - maybe T6 or C bonnet catch - can't remember offhand (I'll check though) Cheers, Lisa |
Cool, thanks Lisa.
Kurt
Fuchs w h o r e
![]() This is a VW Beetle front hood catch. 66 and earlier. |
Is it possible the same latch was used on the 356c cars? There is no reason I should have a VW latch. Thanks,
Kurt
latch
Also used on Karmann Ghia rear engine lids in case you owned one of those.
jeff |
gearhead
I had the same problem with some parts I put up recently. I ended up just putting them on ebay for $3.56 ,no reserve and letting the guys who could use them decide what they were worth. I had no clue on values and didn't want to throw away something someone else might need...
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
