Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Question Moving to Australia, Need to sell 356 engine
Where can I promptly sell a 356 engine. Engine rebuilt 20 years ago, used less than a 1000 miles (in VW Baja), then stored outside in the dry Arizona heat.
Old 04-22-2011, 09:34 AM
Ebay, craigslist?
I'd be interested, but too far away. What are looking to get for it?
64 356C, 87 Audi 4KTQ, 04 A4 Avant 1.8T6MT (Wifes), 82 MB 300TDT (DD), 85 Samurai 1.6 VW TD, 71 Toyota Hilux, 71 NSU1200C, 79 Audi fox, tractors and junk.
Old 04-22-2011, 05:13 PM
1966 - 912 - SOLD
lane912's Avatar
thas the real question...
i was too tired to be pretty last night!
Old 04-22-2011, 06:30 PM
Job offer for Australia requires my presence by mid May. Much to do. Willing to nearly give the old friend away. Hate the thought of sending it to landfill. Would like $2500 but will take less for enthusiast who needs her for their own restoration project.
Old 04-25-2011, 10:06 AM
Post the number. You never know , someone could be looking for that particular unit.
Old 04-25-2011, 07:21 PM
HC lifetime member
obersturm's Avatar
Why not sell the donk in OZ?
Hi there,
I am from Melbourne and if I were you I would take the donk and a whole car over here. Personal imports are permitted if you get permanent resedency/unlimited work visa.
Bring a nice speed yellow 6 speed 993 for $25000 or there abouts and I will buy it off you straight away.
Prices are still high over here for anything Porsche.
Best regards
Marty
Old 04-25-2011, 08:07 PM
naparsei's Avatar
I might be interested, but there's a lot of different engines that went into 356s. Perhaps some pictures and engine #s?
'74 Euro Carrera * '64 356SC Coupe
Old 04-26-2011, 08:37 AM
Geodude,
I'm assuming from your post that the engine has been sitting outside for 15 years or more. Would I be correct in thinking that you are selling this as a rebuidable core rather than a running engine? Look forward to seeing pix. Thanks
Kiwi
Reg # 381
1959 356A Conv D
1967 912
1972 911S
Old 04-26-2011, 03:34 PM
No numbers and more details
Before I sell this old friend, I want to make sure we have completed full disclosure so there are no surprises.
1970ies history: A TWA pilot friend bought lots of rusty Porsches from back east and drove/shipped them to Calif for restoration. Our families rebuilt dozens of them. It was common to have 3 or 4 engines sitting around. I was building a Baja and was offered the engine. I was told it is a 1957, but I never verified this. The engine primary serial numbers had been removed. I was never able to find out when or why. As I was not going to use the engine for a authentic restoration, the exact number was not important. Depending on your use, it may be important to you?
I drove the Baja for a few years before it needed the typical rebuild. (machining done by Conamac in Los Angeles). A few months after the rebuild, I needed a family car, and I let the Baja rest in the back yard in the "Someday Pile".
I built the VW Baja from 3 separate VW bugs around 1980. There were a few modifications needed to put the 356A into the Baja. If you plan to use the engine as an ORIGINAL RESTORATION these will be issues to resolve.
1 The metal skirt part(that seals the engine compartment around the exhaust) is missing, and not useful in the open baja. The metal skirt on the flywheel side may have been modified to fit the Baja?
2 The original motor had a 6 volt generator. I put on a 12 volt (I think it is a 912 generator)
3 The regulator is currently attached to the Baja. I do not remember if it is VW or Porsche.
4 The throttle connection between the VW and the 356 was modified. I think the change was done on the VW parts, but am not sure.
5 There is a bracket on the passenger-side back side of the fan housing that was bent to allow installation. Whatever it holds/held is not included.
6 The tube between the carburetors is/was missing and has a home-made replacement part.
7 The original carburetor filters where replaced non stock parts.
Current
1 Upon removal yesterday, I put a wrench on the crank and verified that it moves. It moves easy for 1/3 a revolution then gets tight. I assume this is due to compression?
2 The carbs are currently frozen. I put some WD on the joints so perhaps they will free up? Gas tank was not attached but do not know if there was gas in the carbs when I stopped using it? Could be goo or varnish now?
3 I have a starter (still attached to the Baja, that I THINK is 6 volt to match the flywheel teeth. I'm not sure? I remember very fast starts so as to avoid not burning out the starter.
4 In 1980ish, I installed aftermarket VDO gages in the baja, which I am looking to sell. These include tachometer, oil temp, oil pressure, voltage, amps, fuel level and a analog clock.
Photos taken yesterday, before removal
Still Interested?
Old 04-27-2011, 01:24 PM
Tags
engine
