Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Timing Light 12V to test a 6V 356 ?
Is it possible to use a 12v timing light on a 6v 356 engine this way ?
I plan to use an external 12v battery to power the timing light while testing a 356 engine that has a 6v electrical system.
I think that the 12 v will power the light and it will not have any effect on the inductive pick up.
Is it safe to do this or there is a possibility that I will break or burn something ?
Old 07-21-2011, 11:23 AM
356RS's Avatar
Your idea to use a external 12 volt battery is correct. I did it that way for years no problems.
Mark Jung
Bend, OR
MFI Werks.com
Old 07-21-2011, 12:31 PM
id10t's Avatar
Yes, but as you said, use an external battery. I use the cheap timing light from sears
Old 07-22-2011, 05:38 AM
Thanks for your answers
Old 07-22-2011, 12:53 PM
