Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
356 Engine identification
I am looking at a 356 that does not have it's original engine. Stamped on the case above the pulley is KD*P*780549. I am assuming this is a 63 1600S. Do the letters mean anything. Should there be other numbers apart from case match numbers. This is all the owner has sent me. Any info would be appreciated
986RON
Old 03-20-2012, 06:07 AM
356graham's Avatar
KD means that it was serviced at the factory at some point in time.
There should be another number on the top of the case - where the two halves meet - that might confirm whether it is a super or something else.
356 Registry has lots of information on this topic. If you aren't already a member, you should consider joining.
Jeff Graham
'56 Speedster
'72 911E Targa
Old 03-20-2012, 06:22 AM
KD stands for 'Kundendienst'. It indicates a factory replacement case; non matching numbers but the next closest thing
Good luck with the purchase!
Old 03-20-2012, 08:10 AM
