What are all these headlight wires??
I am putting back together a 76 911S I picked up recently and I am unsure of what gets hooked up where and to what. The first concern is why are there so many wires in the headlight bucket?
I have H4 headlamps so the connectors circled in red will connect to the lamp ![]() But what are these other two? ![]() Also, for the side maker and turn signal, where should the connectors on the body be for those? The turn signal has 3 wires coming out (large red upper circle), but also 2 blade connectors on the housing itself (smaller red circle, lower left). What gets connected to where? ![]() The side marker seems straight forward, is the long single wire a ground? Where to the two connectors go? ![]() Any help will be greatly appreciated. |
ROW '78 911 Targa
Double WECO connector in bucket is ground(brown) and turn flasher (grey/red) single WECO connector is running lights.
2 wire Jumper from side running lamp plugs into external lugs of turn signal assembly. Black/White is power wire, brown is ground.
@timmy2 thanks! I kind of figured they would connect to the wires in the bucket. I will see if I can get it all sorted when I get home today. Appreciate the help!
