-   -   Distributor cap placement SC (http://forums.pelicanparts.com/porsche-911-technical-forum/1000785-distributor-cap-placement-sc.html)
Wout_RS 06-27-2018 10:05 PM
Hi all,
I am busy backdating the heat on my SC.
As most know the left part needs some remodelling to make some room for the distributor cap.
I saw underneath the cap one bolt. See picture.
Whats the function of this nut/bolt? Can it be for the adjustment of place for the distributor cap?
I would like to know before i start to remodelnthe hot air duct.
http://forums.pelicanparts.com/uploa...1530161999.jpg
timmy2 06-27-2018 10:46 PM
Bolt below vacuum pod in photo is for adjusting timing by loosening and rotating distributor body and then tightening g when correct. Also to remove entire distributor from engine.
