What are all these headlight wires??
I am putting back together a 76 911S I picked up recently and I am unsure of what gets hooked up where and to what. The first concern is why are there so many wires in the headlight bucket?
I have H4 headlamps so the connectors circled in red will connect to the lamp
But what are these other two?
Also, for the side maker and turn signal, where should the connectors on the body be for those?
The turn signal has 3 wires coming out (large red upper circle), but also 2 blade connectors on the housing itself (smaller red circle, lower left). What gets connected to where?
The side marker seems straight forward, is the long single wire a ground? Where to the two connectors go?
Any help will be greatly appreciated.
Old 06-28-2018, 10:56 AM
ROW '78 911 Targa
timmy2's Avatar
Double WECO connector in bucket is ground(brown) and turn flasher (grey/red) single WECO connector is running lights.
2 wire Jumper from side running lamp plugs into external lugs of turn signal assembly. Black/White is power wire, brown is ground.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-28-2018, 11:22 AM
@timmy2 thanks! I kind of figured they would connect to the wires in the bucket. I will see if I can get it all sorted when I get home today. Appreciate the help!
Old 06-28-2018, 11:32 AM
