dim instrument lights
I know that there are many threads on this subject, but I thought that my observation on the subject might help others with the problem. Like others my instrument lights were dim and I was pondering how to resolve it. Over the winter I had pulled my instruments in preparation of my dash pad refurb and windshield replacement. During the process I tagged all my electrical connections on the instrument backs. I also swapped out the radio which meant that I had my hand on the main ground point under the dash (I think it is G2 or3) which is where the instruments and radio get there ground. I realized that the spade connectors were loose on the chassis tab. I corrected the issue and finished my project. My first time out of the garage was after dark and I was surprised at how much brighter my instrument lights were compared to before. So this is an FYI to those who are having this issue and are experimenting with light bulb alternatives. Clean and re-seat all of your power and ground connections first, you might be surprised at the improvement. Warren
Lorraine 83 SC CAB RoW 2003 C4S coupe 07 BMW R1200RT 76 BMW R90S 76 BMW R60/6 |
Cleaning the ground/light sockets and putting new blubs does indeed help.
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
Bandwidth AbUser
Great advice, wolds.
Jim R. |
Member 911 Anonymous
+1 if you want to stay Concours.
But a great alternative is eTarga's antique white LEDs, you can keep the dingy look but it will be clearer or go white and see your gauges in a different light, sorry for the pund. PM him and he can take care of you. :-)
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
another alternative is the 4 watt bulbs from India. huge difference and really cheap. I did the cleaning grounds, new bulbs, etc. and it made the illumination go from "really sucks" to "sucks." the 4 watt bults make it very good.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Always Be Fixing Cars
I'm new to these cars and have been thinking how dim the instruments are. Then last night I realized that besides the odometer, the dimness is not really stopping me from getting any of the information I need at a glance. I'm starting to like it. Part of the charm of the car.
I still haven't figured out how to get the key in the ignition at night though. Guess I gotta spring $50 for a lighted key blank.
'91 964 C4 - New Daily '73 Alfa GTV - 90% done 50% to go '65 912 - Welding in process |
Taking it apart is easy
Anything would be brighter, and 4 watts sounds interesting. Would I blow a fuse with this mod?
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
There is no fuse, you will melt the wiring, so if you do this, place a inline fues. I tried this and it just made the yellowish brighter, I opted for White Light ![]() Etarga WHITE LEDS ![]() Your OEM lights on the Left/ Superbrite LEDS Center/ eTarga Antique LEDs Right
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 04-06-2013 at 12:01 AM.. |
Make sure you get those instrument lights fused. Dimness could be caused by voltage leaking out of the circuit via a short. If this catches up to you in a bad way you could end up with melted wires, a fried headlight switch, and other damage. -- Matt
http://www.unobtanium-inc.com 356 Registry 17369 Early 911S Registry 912 Registry, PCA |
I got them on ebay. based on my understanding of ohm's law, using a half dozen of them add less than an amp to the circuit (i think it was around 0.7 amps but i don't recall exactly). i do have a fuse on my lighting circuit and it has not blown and I doubt it will because the circuit is probably using 4-5 amps total.
82 911 SC - Ancora Imparo
Anyone have a photo and description of the ground point (G2) under the dash? I have some issues with instruments and looking to clean it up. I've been unable to find these details on other threads. Thanks!
Banned but not out, yet..
An air cooled refrigerator. ‘Mein Teil’ Last edited by RSBob; 06-30-2018 at 08:02 PM.. |
