-   -   How to fix a broken aero mirror base (http://forums.pelicanparts.com/porsche-911-technical-forum/1001041-how-fix-broken-aero-mirror-base.html)
175K911 06-30-2018 01:55 PM
When I took my aero mirrors off to get the car painted I accidentally broke one of the two locating tabs off the base of the drivers mirror. After getting over being mad at myself I took a close look at options. The tabs are relatively soft pot metal so I figured I had nothing to lose trying a repair
Located the center of the broken piece, drilled a small pilot hole about 1/4” deep, being careful to keep the drill bit as centered as I could.
Followed that with an 1/8” drill bit.
Got out my tap set and tapped threads into the drilled hole. Sorry, don’t recall which size I used, but I’d selected it to work with a metric screw I had.
Ran the screw into the hole to verify it would work.
Pulled the screw back out to put 2 layers of heat shrink on the exposed threads.
Ran the screw back in with some red Loctite.
Mounted the mirror like nothing had ever broken.
http://forums.pelicanparts.com/uploa...1530391997.jpg
http://forums.pelicanparts.com/uploa...1530392107.jpg
