175K911's Avatar
How to fix a broken aero mirror base
When I took my aero mirrors off to get the car painted I accidentally broke one of the two locating tabs off the base of the drivers mirror. After getting over being mad at myself I took a close look at options. The tabs are relatively soft pot metal so I figured I had nothing to lose trying a repair
Located the center of the broken piece, drilled a small pilot hole about 1/4” deep, being careful to keep the drill bit as centered as I could.
Followed that with an 1/8” drill bit.
Got out my tap set and tapped threads into the drilled hole. Sorry, don’t recall which size I used, but I’d selected it to work with a metric screw I had.
Ran the screw into the hole to verify it would work.
Pulled the screw back out to put 2 layers of heat shrink on the exposed threads.
Ran the screw back in with some red Loctite.
Mounted the mirror like nothing had ever broken.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 06-30-2018, 01:55 PM
