911Sc 993 3.6 conversion oil light and low drunk after a repair
Hey everyone,
I’m a bit perplexed with my cars recent issue.
(Background- 81 911sc to 95 3.6 conversion, I have about 3000 miles on the conversion with no issues up to today’s repair)
The car has a elephant racing front and fender mount oil cooler, this morning I noticed a small oil leek between the front oil cooler and the oil line (there is a wide mouth oil fitting between the cooler and the oil line.) I took the front cooler off and tightened everything down, when I removed the bumper I accidentally sepperated the fender oil cooler temp sensor to the fan, but I doubt this is related.
Anyway tightened the fittings, reinstalled the cooler and added a quart of oil.
A few minutes after I started the car the oil light came on and the drunk pressure read under 1, maybe .65 bar.
I checked the oil and added a few quarts to get the oil to the full mark, but the oil light and low drunk remain. At this point I don’t want to run the car with suck low pressure
One other detail, if I rev the car the light turns off and the drunk pressure rises
I’m not sure what when wrong as this has never been an issue... any ideas?
81 SC 3.8 Conversion
2017 Macan S
INSTAGRAM @tail_spinz
Old 07-15-2018, 12:27 PM
Extra, if I start the car cold it will hold 1.5 bar for a few minutes before the car will drop below 1 bar and the oil light will turn on-
2017 Macan S
Old 07-15-2018, 02:22 PM
Turbonut
Raceboy's Avatar
Get a mechanical oil pressure gauge and hook it up.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 07-15-2018, 07:49 PM
Bill Verburg's Avatar
2 things
the oil pressure sender and gauge don't match unless you changed it, stock 3.6 sender w/ earlier gauges read 2x actual
the gauge at idle always reads low, rule of thumb it should go up ~ 1bar/1000rpm, so at 4k rpm 4bar
Bill Verburg
Old 07-16-2018, 03:13 AM
This
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 07-16-2018, 03:25 AM
a few questions,
is there a specific size mechanical oil pressure gauge I need for the 95 engine?
also, I'm not sure if the timmings swap fixed the gauge reading half to correct somehow, but prior to today the car was always between 2-5, it read just like my old 3.0 engine did... seems weird that it would read half and stay in the range so well- any thoughts?
thank you all for the help.
2017 Macan S
Old 07-16-2018, 06:49 AM
Originally Posted by -Levi- View Post
a few questions,
Getting the correct sender in there isn't easy and is rarely if ever done. Typically a '95 993 swap into a 911 will read ~2bar @~850rpm. That is ~ 2x the actual pressure.
It's hard to imagine the work you described in the 1st post as causing an issue
On a '95 993 the pressure sender is located on top of the engine behind the intake
This is a 964 but the sender is the same as for a 993, just left of center between the vacuum can and the cc vent
Bill Verburg
Old 07-16-2018, 08:00 AM
