G50 Starter Motor Bushing - 964
I have my gearbox out, and got my starter motor over hauled.
Went to clean out the bushing in the trans case where the end of the starter shaft locates.
It appeared to have a cap on the end and when I went to push it out, it just crumbled, so I'm not sure if it was a build up or dirt and grease or decomposed plastic.
Here are a couple of photos to show where it is located. I could not located a plastic cap on the parts listing.. but could see the bushing...
Any ideas?
Old 10-13-2016, 08:07 PM
It's funny that I never read about replacing the bushing on the transaxle case for the starter on this forum. On TheSamba forum (I have a '70 beetle), people replace the bushing as a matter of course when a new starter is installed. I know I did mine. You'd think there would be more discussion on the starting bushing issue... I'll have to check my Bentley to see if they even mention it.
Thought I'd be replacing the starter on my '88 but didn't so I never got that far into it so I can't help you with the plastic cap issue. As it turned out, all I needed was a new ground strap to eliminate my intermittent no cranks.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 10-14-2016, 06:09 AM
txhokie4life's Avatar
Bump, what was the solution?
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 07-02-2018, 09:11 AM
i just cleaned it out, and put a couple drops of engine oil on the bronze bushing...
Old 07-02-2018, 06:47 PM
