Torsion bar removal with factory shark fin rock guard
Long time listener, first time caller. Any tips for removing the rear torsion bars with a factory shark fin?
The cap for the torsion springs is behind the fin. It seems like the car has been repainted with the fin masked off (left in place). Short of repainting the car and applying a new rock guard, is it possible to pull it out of the way so the torsion bars can be removed? Not sure how these were bonded to the car from the factory. Thanks!
Cut around the cover with a scalpel, there is a rubber gasket/molding between the cover and body.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
So, cut the cap out, and then adhere a new fin over the old one?
We use to peel back the vinyl far enough to work, then carefully put it back.
Nah,why do that. Cut in the middle of the rubber molding, you should be able to fold the vinyl under the rubber on assembly.
Torsion Bar Hole Cover Removal…………
Traffic,
You need to remove the following to get access to the TB hole cover
Tony |
Wildman Emeritus
Heat gun to carefully loosen the stone guard enough to move it out of the way to gain access to the cover? Spray trim adhesive to glue it back in place when you are finished? Or remove it completely and replace it; not terribly expensive.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
This. Remove the rubber side trim, heat gun and peel off the old rock guards, and trash them. Do, the t-bar work, apply new rock guards. Put back on the rubber trim. That can be tricky. I cleaned all the dirt and road crud out, and wet the rubber edges with WD-40. It slides right into place. Done.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Not sure where cutting the caps out would accomplish anything other than having a ragged circle where the stone guard doesn't adhere well to the body or the cap. |
Carefully cut?
If in doubt, talk to a local vinyl shop that wraps cars. Buy a set of new rock chip guards, and bring them with you. It should be pretty easy to align the new stickers in place. They spray a soapy liquid on the fender and can position the sticker precisely, and squeegee the fluid out.
It is amazing a pant shop did not peel the stickers before painting your car.
someone had masked and painted around mine. If you peel the old one off,
good luck finding one that will fit your new paint line. |
Once again, go to a vinyl shop with the car. Show them the issue. They can cut a new one to any size and shape from a similar material. If necessary, go to a sign shop. They can make one for you.
