alf alf is offline
alf's Avatar
Red face Help-White Smoke at Start Up after Euro Pre Muffler Install
Just installed the pre muff, will post some pictures when my wife returns with the camera.
Throtle response much improved. Feels like more power and torque across the range. Not any louder but makes a really nice low rumble and burble.
BUT...my previously non smoking, non leaking 3.2 just started puffing white smoke at cold start, after 10 seconds it will puff white smoke for 3 to 4 minutes. No smoke on warm starts or any other time. Idle also seems to be a tad bit higher.
Any ideas what is causing the smoke, i understand white smoke is primarily moisture, but where is it accumulating?
88 Carrera Coupe
Pelican Since 2002
All Zing, No Bling. ok, maybe a little bling.
The Roach
Old 03-02-2003, 01:59 PM
alf alf is offline
alf's Avatar
Stuff you need. 3 gaskets and 9 nuts and bolts. I got the copper nuts that are not suppose to bind.
What the pre muff looks like on the inside. Pretty much a hollow pipe with finned walls.
Took a couple of hours to take the old cat out and bolt this on. One stuck nut that required a dremel, hack saw and 30 mins.
88 Carrera Coupe
Pelican Since 2002
The Roach
Old 03-02-2003, 02:50 PM
Senior Member
Doug Zielke's Avatar
Alf,
All I can think of is the (used) pre-muffler has some oil or other contaminants inside of it. Take 'er for a good long romp and see if things clean up.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 03-02-2003, 05:23 PM
alf alf is offline
alf's Avatar
I hope that is all it is. Another excuse to go romping Hey, my wife loves your cat, is that a korat?
alf
88 Carrera Coupe
Pelican Since 2002
The Roach
Old 03-02-2003, 06:06 PM
canna change law physics
red-beard's Avatar
I think you'll find it's a metal preservative. It will burn off in no time.
James
James
Red-beard for President, 2020
Old 03-02-2003, 06:19 PM
alf alf is offline
alf's Avatar
James
Thanks for the insight, but wouldn't any preservative have already burnt off? That thing is from a early 80s car. Or does it sort of reactivate itself after sitting for some time?
88 Carrera Coupe
Pelican Since 2002
The Roach
Old 03-02-2003, 06:49 PM
red-beard's Avatar
Oh, so sorry. I thought you installed a new one. I put a new muffler on my 914/6 and it smoked for a few minutes.
Hmmmm. Maybe it is perservative, the leaking oil kind...
James
James
Old 03-02-2003, 06:55 PM
Send a message via ICQ to old_skul
My car does this too in cold, humid weather, with a stock muffler/cat. It's just condensation. Different types of metal, and where you store your car (indoors or out) can affect how your car reacts. Mine just gets a lot of condensation in the exhaust, and it sounds like yours does too now.
There's also the possibility of a bad O2 sensor, or installation of it. That could make it run rich, but I would think unburned fuel would come out as darker smoke.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 03-03-2003, 11:54 AM
alf alf is offline
alf's Avatar
Update. I've discovered that it is only smoking when it is on cold idle. Driving immediately after start up eliminates the smoke unless i am idling at a stop sign within the first couple of minutes.
Perhaps it is some engine management thing that forces a rich mixture when it is cold that does not burn off at idle rpms. The OEM cat might have filtered the smoke out before.
Anyway, its in for a valve adjustment and new plugs this afternoon and the tech is going to check out the smoke.
alf
88 Carrera Coupe
Pelican Since 2002
The Roach
Old 03-03-2003, 01:21 PM
