Dont shred your door strikers.....
They are not an Allen Key and they are not a Torx bolt, they use an 8mm "triple square socket". Bolts come preloaded with lock tite so they are a ***** to get out if you strip them and you will without the right tool.
79 SC unmolested 75 911 backdated RSR widebody 71 911T having fun skinny 63 356 outlaw frustrating purists 25 GTS |
Thanks. I'm getting ready to replace mine. Host sent me the replace me recently but I better check the tool chest for the right fit.
1987 Guards Red Targa, cams, exhaust, MFI intake, lowered, 7 and 8's, 200,000 plus miles of smiles |
911 enthusiast
I’ve also seen these called XZN sockets. They take the door strikers off easily when attached to a moderately-sized breaker bar. Pro tip I saw on here: undo one bolt entirely, loosen the other - but leave it screwed in for a moment. Swivel the door striker out of its own way and put the first bolt back into the empty hole. Then remove the other bolt and you’re holding the striker in your hand without risking some kind of backing plate sliding around inside the door frame.
Fleabit peanut monkey
![]() A set of them are pretty cheap from the auto parts store. I have seen them (fasteners) on newer VW's. Napa sells a much higher quality set. KD, I think. You pay for them.
1981 911SC Targa |
Good post Eddie!
Tru6 Restoration & Design |
That's a land mine waiting on the trail, thanks IRL !
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
I replaced mine last year after seeing the plastic was broken inside. These are not something that you'd normally associate as a wear item.
Steve '66 912 - Polo Red; '74 911s - Silver Carrera RS clone '77 911s - Peru red IROC Clone '89 964 C4 - Guards red |
There's a kit to replace the plastic inserts.
Jason - Austin, TX 82 911 SC targa (gone, but not forgotten) 92 968 coupe |
Red Loctite ? holy crappers.
yeah those zxn or " triple square" are used all over my audi too.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
kit for replacement
where do you get he kit to replace the plastic?
1975 911S Targa Silver Anniversary Edition |
Scroll down a little
https://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2016.cgi?command=DWsearch&description=door+striker
SIC-531-701-31 is the part number for the rebuild kit.
'73 911 T Targa
Wow, lots of great advice here. I got new strikers and had planned to do the job with a Torx. You guys saved me from. Disaster.
Thanks Shaun, you just saved me a ton of money!
Careful what you wish for... |
911 enthusiast
Great upgrade. Less than an hour to do both sides. The passenger side was in slightly better shape, but not by a lot. Plastic pieces were pretty gnarly after 30+ years.
Good info. Thanks.
1976 911 S Targa 3.2 |
might be a good idea to mark off with a temporary marker where they go on the body before removing them . Will make alignment easy.
So has anyone found a reasonably-priced triple square bit set? I've found some online, but they all seem to use 3/8" drive for the 12mm size, and I would prefer 1/2" (for flywheel bolts).
Might have to just get the 12mm separately. Mark
1979 911SC Targa |
I got a separate one for mine Mark .
A "good Bit of kit" as the English would say . ![]() it's a Hazet 990
Thanks, that does seem to be the way to go.
Mark
1979 911SC Targa |
