DSM DSM is offline
DSM's Avatar
Re-sizing BBS E50 to 17"
Re-sizing these stunning BBS E50 to 17". OEM BBS parts on order....
Current Size: Front 16x8 (205 55 16) / Rear 16x10 (245 45 16)
Re-size: Front 17x9 (255 40 17) / Rear 17x11.5 (315 35 17)
Old 11-22-2022, 02:45 AM
IROC's Avatar
That's beautiful! And some serious tire!
I did something similar. I re-sized my HRE Fuchs replicas and went from 8x16/9x17 (running 245/45-16s and 275/40-17s) to 8x17/9x17 but wimped out and am now running 225s/255s.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 11-22-2022, 04:04 AM
Shaun @ Tru6's Avatar
Beautiful wheels and looking forward to the transformation. Are you still running factory spacers in the rear? I'm restoring a set of centers and have pieced together inner and out halves to make 7.5 front and 9.5 rear for the same tire size. But my rears are very deep and am pretty sure I will just have to remove the spacers to fit them in the arches.
Did you get all new hardware too? Source for everything?
Tru6 Restoration & Design
Old 11-22-2022, 04:15 AM
DSM DSM is offline
DSM's Avatar
No spacer on rear of blue 930. Will be using existing hardware and sealing ring. Will seal with Soudaseal 270HS. Used this sealant on the 18" OZ wheels. Worked perfect. The BBS E50 wheels are in amazing condition now, just want to size up. I like fitting alot of beef wellington under the arches.
This is where I ordered. They only accept wire transfer from USA. Anyone have experience with them? Wrong time to ask... I know. Order placed 10/11/22. Shipped 10/26 but was return to sender on 11/7. Hopefully this gets straightened out and parts arrive soon.
https://shop.felgen-renninger.de/
Old 11-24-2022, 07:31 AM
DSM DSM is offline
DSM's Avatar
Old 11-24-2022, 07:49 AM
Cory M's Avatar
Dow Corning 832 sealant is readily available in the US from places like McMaster-Carr and is what is used by some wheel OEMs to seal 3 piece wheels. I've rebuilt a lot of wheels using it, following the recommended instructions, and I've never had one leak.
Old 11-24-2022, 11:03 AM
I believe you can buy the halves and hardware from BBS (Georgia)
Old 11-25-2022, 06:43 AM
DSM DSM is offline
DSM's Avatar
These finally arrived last night. Happy new year to me!
Old 01-01-2023, 06:41 AM
LJ851's Avatar
Wow !
Old 01-01-2023, 08:23 AM
Excellent post! - have a similar set of 16' E50's and planning same size 17' 9 & 11.5 for the 930. What is the combination used for the rim halves, inner and outer rim sizes to avoid the spacers?
Old 01-02-2023, 05:12 PM
DSM DSM is offline
DSM's Avatar
Rear = no spacers on my 1977 930. Not sure about front. I added to inside only.
Old 01-07-2023, 06:25 AM
DSM DSM is offline
DSM's Avatar
Some pics of center and rear 11.5"
Old 01-07-2023, 06:33 AM
DSM DSM is offline
DSM's Avatar
For ref: 16x5.5 Outer Left & 17x5.5 Outer Right
Old 01-07-2023, 06:46 AM
These are simply beautiful DSM,... and look fab on your car.
Tell me, are you using the black rubber gaskets in ADDITION to the sealant? or sealant alone?
I have been assembling BBS E26 wheels for years now for a pure race car application using only then gaskets. never had a problem
thank you. FRank
Old 01-07-2023, 08:04 AM
DSM DSM is offline
DSM's Avatar
thank you. FRank
Plan is to install large ring without rubber O-rings then seal. I’m sure the O-rings work but I prefer sealant.
Old 01-10-2023, 01:43 AM
onboost's Avatar
Wheel update is beautiful! Should be stunning on that 930!
Now on another note.. the wife is gonna have your arse about car parts on her table! Lol!!
We all do that don't we!
RGruppe #180
Old 01-10-2023, 03:51 AM
DSM DSM is offline
DSM's Avatar
Old 03-12-2023, 04:18 AM
Wow beautiful
Old 03-12-2023, 08:15 AM
Originally Posted by DSM View Post
Hi DSM. Any updates regarding the BBS E50’s? Currently in the process of doing the same to mine and would love to see the end result
Old 02-05-2024, 07:45 PM
DSM DSM is offline
DSM's Avatar
Old 02-06-2024, 08:42 AM
