cmpski's Avatar
Lower targa window trim
The car is a 86 Carrera.
The trim I took out had all kinds of hammer marks.
I was doing fine tell I got to the corner. I haven’t figured out how to get the rubber trim to seat properly around the corner. What is the solution.
Chris
Old 09-01-2018, 12:36 PM
universeman's Avatar
Must be done before you put the window in. Impossible once the glass is in the car. Trim goes into seal first, then seal onto glass, then glass into car. You can’t bang or push it into place after the fact; you’ll ruin the trim. Lots of threads on here about targa back glass install. Good luck!
Old 09-02-2018, 07:00 AM
RDM RDM is online now
Coram Deo
RDM's Avatar
A miserable job. Universeman is right; the trim has to go in before the window/seal goes on the car.
Here's my experience: SC Windshield / targa window seal replacement and trim refinishing
There are other good threads that I read from.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 09-04-2018, 06:28 AM
Yep. The trim gets installed into the rubber before you put the glass in the car.
78 911SC Targa, GP White
Old 09-04-2018, 07:57 AM
