What is a Turbo finsh on a fuch wheel?
Looking for what the Turbo finish with the outer barrel polished and then (milky clear) anodized, looks like? I have spent most of the day look at previous postings but nothing on Turbo finish. All the fuch wheels look the same to me with the exception of a polished lip.
Any pics would be appreciated
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster |
All of them had the same outer lip finish, clear anodize. There is no "turbo" finish.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
The wheel on the right here is a 9x16 w/ the finish you are looking for
Formerly known as Syzygy
Maybe you're thinking of an RSR finish? Otherwise, as Jeff has pointed out, there is no specific turbo wheel finish.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Okay, here's the deal. Harvey Weidman sent me this email and hasn't clairified my question in regards to the Turbo finish. I understand he is very busy so that's why I came to you guys seeking help. Anyways here is his email and perhaps you can clarify my not understanding.
"First, the spokes anodized and the outer rough offset with the smooth lip. (similar to the 74-77S but wider wheels) Second, the center black with the outer rough offset and smooth lip. (like 75 Carrera USA) Third, the center black with the offset and lip smooth. (Like 75> Turbo and all 16" wheels) None were polished. The finish that I was referring to that I call the Turbo finish has the outer barrel polished and then (milky clear) anodized. This became available as a option in 76 but very few had them."
Here's what my wheel looks like. I need to refinish the wheel because it should not be polished.
So, I am going to have the polished lip and the rest anodized look. Since this is a ROW 76, I was curious of what Harvey meant by the turbo.
I don't know what you mean by "milky clear". I assume you're referring to the barrel like the right hand wheel that Bill showed. That is what the stock wheel that every turbo had except possibly the earliest examples.
I'm not 100 percent sure what Harvey means in his descriptions, but this is my interpretation... First: an RSR finish which has silver (not painted) spokes with a rough texture anodized finish on both the spokes and the wheel rim but with the smooth and thus shinier wheel lip. ![]() ![]() My Weidman finished RSR wheel ![]() Second: I suspect this is much the same as the RSR but with the centre all black and no silver spokes. ![]() Third: This is what the turbo and almost all other Fuchs wheels were from the factory from the early and mid- 70s and later. ![]() ![]() The description from Harvey you list seems a little ambiguous and not exactly clear, so this is just what I think he means.
So, original Fuchs were NEVER polished from the factory correct???
Cars and Cappuccino
EDIT: The "un-adonized" lips may actually be clear anodized. Last edited by tdw28210; 07-13-2018 at 11:51 AM.. |
Thanks. There is an 88' Targa I have been looking at, but they polished the Fuchs and it is a deal breaker for me. Just my 2 cents . . . . |
"Milky clear" is Harvey's words, and that is part of what I am confused about
The bottom line is I want it to look original as possible, I do not know how my car came from the factory as far as the wheels is concerned, would I be safe with the RSR or with the black center,anodized rim, polished lip or.....? Your professional opinion is valued
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster Last edited by bcgreen; 07-13-2018 at 10:55 AM.. |
raw polished aluminum will oxidize fairly quickly, you need to keep after it to keep the gleam, an anodized finish like Fuchs use is somewhat better in that regard but is still fragile. from the factory the '76 wheels are visually the same as the ones w/ black centers pictured above. The RSR finish is a frosted matte, ie even less gleam than anodized
Would I be original/correct, with your pic. above, with the black centers or this pic. below?
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster Last edited by bcgreen; 07-13-2018 at 02:03 PM.. |
'76 would have had anodized lip and black center
here is a correct '76 Carrera 7x15
![]() and a correct '76 Carrera 8x16(missing the valve stem support)
Bill, you have the 3.6RS and mine is the ROW 76 Carrera 2.7 mfi, do you think that makes a difference for the wheels?
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster Last edited by bcgreen; 07-13-2018 at 03:21 PM.. |
I think what Harvey is trying to say is the outer lip is clear anodized, the barrel ( I think he is calling the offset) is rough anodized, thees two parts are just like the RSR wheel but the center is Black. The "milky clear" is how the bright anodized lip should look. This style Fuchs is hard to photograph.
75 911s 86 951 sold to make room for baby seat 09 335i 6MT NVH |
4th set of wheels, 4th engine, 2nd trans, 3rd set of brakes etc. the original engine was a 3 liter, as opposed to your 2.7, my trans has an electronic speedo, where yours has a mechanical. But the wheel, tire and suspension options were the same. the above 7 & 8 x15 w/ 205/50 & 225/50 were an optional wheel/tire as I outlined above.
This is an original correct RSR ![]()
