7783911's Avatar
hard oil lines nut size
Can some one confirm for me the nut sizes for the oil to external thermostat lines
Small one is 33MM, what is larger one?
Old 07-17-2018, 07:10 AM
36mm
30 is smaller size. 33 not a good size
Bruce
Old 07-17-2018, 07:13 AM
7783911's Avatar
33 is wghat i gleaned from another post but it also said the larger nut was 1 7/16 and i think its larger. this must be listed somewhere in a catalogue?
Old 07-17-2018, 08:39 AM
Once a friend of Cliff
juanbenae's Avatar
1 7/16 is a hair too big. I got one of those open sockets for the work some years ago and it as I said was a bit too big. I might suggest the harbor freight metric large shorty wrench set. they got from like 20mm to 36mm and are prefect. they are short wrenches with a tapered handle for cheater bar application.
Old 07-17-2018, 10:06 AM
7783911's Avatar
i ve gotten a 30 and 36 mm coming tomorrow..try those and see...was 77 targa different from most..lord only knows
Old 07-17-2018, 10:34 AM
7783911's Avatar
Flatpac..thats was typo on my part..i have a 30mm that fits the small nut, 36 coming tomorrow
Old 07-17-2018, 10:35 AM
KTL KTL is online now
Schleprock
KTL's Avatar
36mm is correct. I have a set of oil line wrenches I got from another porsche supplier almost 20 years ago and they are 36, 32, 30 and 27. 36 gets used ALL the time.
edit............. the name got nixed by the forum word blaster. I gots ways around that!!!
Kevin L
'86 Carrera "Larry"
Old 07-17-2018, 10:58 AM
7783911's Avatar
Thanks Kevin....may order because cant have enough tools for a porsche!
Old 07-17-2018, 11:24 AM
76 911S Targa
I wanted a flare type 36 mm so I bought a Ford axle nut deep 36mm socket for $8, cut off the last 3/4" of the socket, welded it to a 1/2" drive extension and then cut a slot in the socket to pass around the oil line. Worked great because the flare wrench could not slip off the 36 mm nut. Easily turned with a 1/2" drive ratchet. It was the only way I could reach up from below and tighten the nuts onto the external thermostat.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 07-17-2018, 12:17 PM
7783911's Avatar
would love to see a picture or 2 of that Targalid....
Old 07-17-2018, 12:35 PM
I found them to be anything but perfect. The 30mm was about 31mm and the jaws were cut or ground at an angle. It was gouging my oil line and finally stripped it. I found a 30mm box wrench at Home Depot for $10 and cut the box end to mimic a line wrench, it worked much better.
_______________________________
1982 911 SC 240,000mi and counting
Old 07-17-2018, 01:03 PM
7783911's Avatar
how much do you have to cut out...i dont want to over do it?
Old 07-17-2018, 01:20 PM
76 911S Targa
Photo attached. You can see the socket with the cut marks on it. It still works as a socket.
Old 07-17-2018, 01:29 PM
juanbenae's Avatar
I found them to be acceptable. I did a search on HF to attach a link but it appears they no longer carry them.
Old 07-17-2018, 03:12 PM
Flojo's Avatar
This worked great
https://www.ebay.de/itm/Hahnenfusschlussel-SW-36-mm-Offener-Ringschlussel-Steckschlussel-Hahnenfus-Nuss/261776650880?epid=1204768128&hash=item3cf31ab280:g:PSAAAOSwpDdU3iIo
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 07-17-2018, 03:50 PM
