-   -   Tachometer with rotated numbers (http://forums.pelicanparts.com/porsche-911-technical-forum/1002673-tachometer-rotated-numbers.html)
WP0ZZZ 07-18-2018 08:28 PM
I would like to change the tachometer in my SC to get something similar to this (upright numbers, redline at 12 o'clock & up to 8000 rpm):
http://forums.pelicanparts.com/uploa...1531970191.jpg
I think that the transformation is not as easy as just rotating the tachometer and replacing the dial since the high beam and turn signal indicators would be rotated and in the wrong position.
Do I need to get a different tachometer or is there any way to convert the stock one to this configuration?
Tbone1209 07-18-2018 11:27 PM
Palo Alto speedo or Hollywood can both do that
WP0ZZZ 07-19-2018 06:39 PM
Isn't there an off the shelf solution I could buy?
dicklague 07-19-2018 06:48 PM
I had NHS do mine years ago and it came out great. Will try to get a photo.....that is the ONLY way to accomplish this....of course they also make the internals like new at the same time.
Porchdog 07-19-2018 06:51 PM
When mine stopped working a year ago I sent it to NHS and had them rescreeen and clock the face as above. It looks great.
Their service wasn't great.
Tbone1209 07-19-2018 06:53 PM
Off the shelf? For rescaling the internals of the gauge? Uh.. No
WP0ZZZ 07-19-2018 07:55 PM
You reckon rescaling the internals is essential?
Looking at the image in my first post, I would guess that the angle between 0 and 8 is slightly less than 90 degrees. However, the angle between 0 and 7 in a stock SC is larger than 90 degrees. This is why I thought that it might be possible to keep the same scale (as measured in needle degrees per rpm) but add the extra numbering up to 8.
It could well be that everything is extremely complicated and better to be left to a pro but I would like to know why. ;)
bluebox88 07-19-2018 08:08 PM
You've answered your own question...........
"everything is extremely complicated and better to be left to a pro"
1. Send it to PAS
2. Be happy
WP0ZZZ 07-19-2018 09:03 PM
You didn't read the "I would like to know why" part! :D
I like Porsche because of the journey, not just the goal.
oh snap 07-19-2018 09:10 PM
you can twist the tach in its position to get the redline to the top. Or make a new face and install over the old one with the needle in a new resting position near 5oclock
See here for a face design. Not sure if anyone makes one off the shelf.
http://forums.pelicanparts.com/porsche-911-technical-forum/578911-84-89-carrera-tach-upgrade-0-8k-rpms.html
WP0ZZZ 07-19-2018 09:50 PM
Thanks very much for the link to that thread! The OP of the thread says:
Originally Posted by scarceller (Post 5711960)
While doing these repairs I saw how easy it's to take this tach apart and remove the needle (pointer indicator) and the tach face with the RPM scale. When you put the needle back you can place it in any position you like, this got me thinking: I could easily configure a offset tach with 6000RPM at 12 noon position and then extend the scale out to 8000RPM just for fun. But the tach would never swing past 7000RPMs the 7-8K range is just for looks. Redline on this car is 6800RPMs, chip change.
oh snap 07-20-2018 01:16 AM
lol. sorry about that. no more posting before my morning coffee.
anglophone1 07-20-2018 01:40 AM
Look at this thread http://forums.pelicanparts.com/porsche-911-technical-forum/917067-aftermarket-tach-install.html
I just had my shop install one of these- with a custom face and shift lights- USD 200 or so- 4 week delivery
C
T77911S 07-20-2018 04:11 AM
the RUF tach, but why pay big $$$ for that when north Hollywood can do it.
Porchdog 07-20-2018 05:00 AM
I drove for decades with my tach rotated.
I would not have had the face rescreened and the needle clocked if I wasn't getting the tach repaired anyway. It is nice to have the turn signal indicators in the correct position and nobody asks why my tach is screwed up any more.
NHS's workmanship was fine. Given their service I would try PAS if I was doing it again.
Jesse16 07-20-2018 05:53 AM
I just rotated both the tach and speedo and never looked back. When people see it they have to ask and it gets a short conversation started, usually a nice moment. Easy to un-rotate when my "go to the track" days end. Just wanted to see the tach needle at 12:00 for shifting purposes and get the 100 mph range from behind the steering wheel. An actual complete gage update is nice but not necessary for me at this time.
pampadori 09-25-2019 06:44 AM
Old thread revival!
The SC tach goes to 7k. NHS told me that going past 7k wears out mechanisms and can cause issues so they can rescale it to have the same sweep but calibrate for 8k to be where 7k currently is. Then you pop on new artwork and they can rotate it to whatever angles you want while in there. This runs between $450-$550. If you want 9k or higher then it costs more because they must replace a board too. I'm revving to 7500 or less so don't need to go past 8 for visual.
Besides the first pic in this thread (which looks amazing!) does anyone else have a pic of their modded tacho?
Sebscst 09-25-2019 11:03 AM
Here’s mine, adjustable shift points and redline with indicators.
Daytime
http://forums.pelicanparts.com/uploa...1569434552.jpg
Nighttime
http://forums.pelicanparts.com/uploa...1569434630.jpg
dicklague 09-25-2019 01:29 PM
Daytime
Nighttime
Interesting!! the speedo looks really dumb that way.
Sebscst 09-25-2019 05:46 PM
Yes, but it’s the only way I can see 60-90 mph without the steering wheel obstructing the view.
ian c2 09-26-2019 07:13 PM
Here’s what’s going on my “new” car ...
Hand-made for the “old” car by the guy that did the factory turboS gauges , but he replaced the turbo S writing with CARRERA writing .
Still sitting on a tote after traveling from England around 10 years ago , just waiting to be installed .
With hindsight , I probobly should have left as it was :D
I like it it , and that’s all that really matters ...
As I’ve got older I’ve come to appreciate a “high-rpm” tachometer twisted slightly counterclockwise .
I think it looks much more Gooder than the “red-line-top” thing ..
http://forums.pelicanparts.com/uploa...1569550151.jpg
