Druck Gauge at 0
Newbie question. 83SC.
The druck gauge used to work perfectly. No issues at all. I had some work done on the ac - system recharged and some dryer piece behind the steering wheel needed to be replaced. The gauge now just reads 0 all the time. When I start the car it goes from below 0 (resting) jumps a bit to 0 but never above. Drove the car for about an hour tonight - some highway and stop and go and no bad symptoms at all. Drives exactly the same. No warning lights ect. Gauge just never moves. All other gauges work great. Oil level in the middle when stop on level. Oil temp around 210. 1. Does this just sound like a gauge issue - nothing big to worry about 2. What's the best way to start and diagnose this. I read the if it's the sender unit it usually goes to 5. Thanks for any help. |
The sender is about $70, if there is no connection at the sender but wire is good dash guage pegs to the top so going negative would be at the sender.
My thoughts Bruce |
Just an FYI when the “druck” gauge reads 0, that’s supposed to be your cue to immediately shut the engine off and sort out the trouble. By driving it for an hour that way you have basically confirmed that the trouble is with the gauge/sender rather than the engine itself. If he problem was isolated to the engine the damage you would have done with 0 pressure would have been devastating. Your engine would be a boat anchor and you would have been stranded. Oil pressure is not a suggestion.
You might want to start out by removing the gauge from the dash to ensure that there are no wires that have become dislodged. To remove the gauge you can grab the rim and gently rock it side to side while pulling towards yourself. It is only held in place by a band of rubber that encircles the unit - creating a tight fit in the dash cutout.
__________________ David Yerkes 1987 911 Targa - GP White |
Cars and Cappuccino
Sounds electrical or wiring related. Trust the stick, not the gauge. Even on their best days, the gauge is only directionally accurate.
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
Brew Master
IIRC there's a way to test by grounding the wire with the car off or something along those lines. Do a search and you'll find out how to test. My guess is you lost the sending unit. I think when you ground the gauge should peg and drop back when you remove ground.
Ok I'll check the gauge first by pulling it out and checking to see if anything came loose.
There was no oil light on or anything so that's why I kept driving home. It just seemed like a gauge issue since it doesn't bounce or move all at. It's not like it was at 3 then dropped to 0. From my understanding it's a sump system. So when I'm stopped and the car is warm my oil level gauge jumps up and reads in the middle which means oil level is good. When I start driving the oil level drops to red which to me means the oil has left and is circulating around the engine which then should make the druck gauge rise. Am I correct in this or totally wrong. Last edited by mattypV50; 07-18-2018 at 06:57 AM.. |
Fixed.
Took the gauge out of the dash - pushed some wires in...started it up and 4 bars on startup. Nice! So if this helps anyone else in the future as most posts are about the gauge being pegged to 5.... Symptoms: 1. Druck Press Gauge at resting position when car off 2. Turn ignition and gauge comes up the 0 mark and oil light is on 3. Start the car and the gauge doesn't move but oil light off and car is running fine Solution: 1. Gauge wires in dash were lose / bad connection |
Member 911 Anonymous
Good Job.
Consider removing and polishing/tightening those connectors. Nice when it is simple, huh?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
