Dreaded speed control hang up.
Another solution to use besides the plastic tie. 18 gauge wire. Strong stuff, easy to work with .
Nice solution! Unique vantage point for the picture.
I sure wish there was a source for new bowden cables for the cruise control. When I had to replace my broken one the used one I finally found only had one plastic clip left. I just used the X pattern and two black stout zip ties.
Your method works.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Spiderman
Kinda like that, may consider replacing my zip ties.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
In my DOD job we used safety wire on many weapons systems. We used safety wire pliers That would lock the wire and then you could use the tool to spin the wire and then cut the end and fold it over. I sure wish I had that tool.
Coram Deo
Safety wire pliers were for amateurs. Everyone in my munitions shop did it by hand to avoid the pliers' tooth marks and slight variation in twist size. (I think we have some background in common here that dare not name)
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
RDM, I think we may....
Coram Deo
Strategic Air Command, 1987-90....
Special weapons mechanic, San Diego CA
There they are!!!! They worked well. We were required to use them because they did a very neat job. Many times we would install a small lead seal at the end of the twist then QA would stamp it and then we would twist and cut off the end and fold it over . Thanks for finding them.
El Duderino
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
I got one too but they are not cheap. They are still available. I'm pretty sure I had to get it ordered from Porsche in Germany and wait a couple of weeks to get it.
