Senior Member
Cleaning Deck Lid Louvres
The rectangular grate, with horizontal fins like louvres, is part of the rear deck lid and sits right above the engine. It is made of black plastic. '78 911SC. Mine has turned sort of a hazy grey. I think it should be black. Has anybody successfully cleaned/refurbished this? How?
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
If that fails, remove primer & re-paint with heat paint. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Coram Deo
I removed mine (6 t-bolts, 6 tiny nuts, 6 tiny washers) and had it Cerakoted flat black.
It's easier to get out if you've removed the A/C condenser, but not hard either way.
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
Senior Member
Guys, I'm not sure I want to paint it. I'd rather just restore to original. It is made of plastic. I am thinking that a good cleaning and coat of silicone would make it look new, but I just do not know what to clean it with.
https://www.carpro-us.com/protection/cquartz-dlux-wheel-trim-coating-30ml-sky-kit/ Or just use their Perl which is for plastic, exterior, rubber and leather. It will give it a deeper color but you will need to reapply, I guess monthly depending on weather and if car is left outside. Ctopher |
Coram Deo
The plastic has been in the ozone and UV for 40 years; I don't know if there's any undoing that.
Not sure if you want the grille to be glossy. I don't think they came that way.
