THE REDNECK MEXICAN
riverstonefly's Avatar
Will pre 964 none power sport seats bolt into a 964
Hello all quick question....trying to shed some weight but still keep factory sport seats and was wondering if pre 964 seats will just bolt in.
jr
Old 07-21-2018, 07:54 PM
Yes same bolt pattern.
Old 07-21-2018, 09:52 PM
Formerly known as Syzygy
Canada Kev's Avatar
They would have to be '84 (I think this is the change year) and earlier as the later 3.2 sport seats are the same as the ones found in the 964.
Kevin
Old 07-22-2018, 08:26 AM
I have available to look at a 84 turbo with sport seats and it uses the 85 and later seat base welded in the chassis.
Bruce
Old 07-22-2018, 08:56 AM
Canada Kev's Avatar
Yes, the bases are the same. I was referring to the style of the seat; the earlier ones are not powered and lighter, while the late Carrera sport seats are the heavier electrically powered units and exactly the same as those available on the 964 except for the upholstery pattern.
Kevin
Old 07-22-2018, 09:26 AM
4flyboy's Avatar
Will bolt right in, amazing weight savings.....
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 07-22-2018, 09:37 AM
THE REDNECK MEXICAN
Sent from my XT1650 using Tapatalk
Old 07-23-2018, 10:20 AM
THE REDNECK MEXICAN
Thanks bro
Old 07-23-2018, 10:21 AM
THE REDNECK MEXICAN
Appreciate the info amigo
Old 07-23-2018, 10:22 AM
THE REDNECK MEXICAN
Wonderful so just need seats and sliders
KTL KTL is offline
Schleprock
KTL's Avatar
You don't necessarily need to source sliders. Pretty much most, if not all, Porsche seats you will buy used have the base frames still attached to them. The sliders are typically kept with the seat base frame.
Kevin L
'86 Carrera "Larry"
Old 07-23-2018, 10:39 AM
